Snowmobile engine in to tube frame buggy, radiator hoses ?
AnotherFatBoy
I am putting a Polaris 700 Liberty in a tube frame buggy and the path of the cooling hose to a new radiator is confusing. The front of the engine has a hose barb that I assume is an input line. The top of the motor has two hose barbs, I assume the top is an output after a thermostat. What does the bottom of thermostat hook up to ? Does there have to be a circle created so before the thermostat opens that helps warm the engine to the correct temp ? View attachment IMG_7486.jpegView attachment IMG_7487.jpeg
Sparkwizard
Richlands ,NC USA
It looks like there should be a "Y" from the two black plastic parts to the upper housing. Top barb and lower, front barb are radiator hoses.
Old mechanic making an educated guess here.
Might be a thermostat for each cylinder in the black housings? Maybe?
AnotherFatBoy
The black plastic is part of the manifold intake, no coolant runs thru there. The connection is the bottom of the thermostat. I think the top of the thermostat runs to the radiator and the bottom of the thermostat runs to a Y at the front of the motor.
Sparkwizard
Richlands ,NC USA
It looks like there is a water pump in front where the inlet is, and a hose connector to a pipe feeding water to both cylinders. Can you verify there is a thermostat in that upper rear housing? If that was a heater hose below that housing, there must be another hose barb somewhere.
You don't have the original sled, do you?
Google says it had heated running boards.
AnotherFatBoy
I do have the sled, the hose's also run to the top of the tunnel and the brake caliper, an overflow bottle, yeah two ports at the thermostat and one in the front.
AndreyStankotorg
AnotherFatBoy — yes, you want a bypass so coolant can still circulate and the engine can come up to temperature before the thermostat opens to the radiator. On most of these twins the lower port on the thermostat housing is that bypass, teed back into the front (pump) inlet, and the upper port goes to the radiator — which is what you already suspected.
Since you still have the sled, copy those hose runs first: note what is on the two thermostat ports, the front barb, the tunnel, the brake caliper and the overflow bottle, then decide what the buggy actually needs. The tunnel and caliper lines are a heater circuit. If you drop them, keep a bypass of similar restriction and keep the overflow bottle in the loop so the system can expand. Do not cap a port just to tidy the engine bay — you can end up with no bypass, or a trapped air pocket. Bleed it carefully the first time you fill it, and watch the temperature on a short first run.
AnotherFatBoy
Thanks, I think the thermostat allows coolant out the bottom then when it gets hot enough kicks it out the top.
