Newbie
tigeriron
Bedouin Rug Trader & Horologist
Western North Dakota
Hello.
I'm a modestly experienced mechanic, owning 9 vehicles & always tinkering.
Last year I picked up a KT196 for my son.
It was a used unit, but virtually BRAND NEW. The folks had used it once..... They claimed they used it for 10 minutes... And the engine froze. My guess is that they simply overlooked checking the oil level in the very beginning.
It was a bargain (to me) at $700, as retailers here in Western ND sell these at about $1,400 at the time.
I had a new electric-start 7HP engine sitting here for another project, and I added a new clutch (Parts missing, as they were assessing the failure). My new engine was an exact-size replacement. I added a box for the battery, making a clean set-up.
Anyway, I went through a half dozen belts, my learning curve, getting the belt alignment understood.
We live in a very rural place, no paved roads, plenty of dust, but hard soil and few grassy places to ride. The Drive-system-cover mounts have already failed, so that's been removed. I use BRAKE-CLEANER to remove gum build-up. This seems to work well, and I've not noticed any belt degradation with that use.
Everything seems to be running well, but now I'm considering learning more about tuning & modding.
My first interest is in replacing the 'clutch & torque converter' with a chain drive, in lieu of the belt.
Is there any thread sharing the pros/cons of this?
Best Regards,
TIG
Thepartsguy
I’ll jump in here and say it before other members do!
Pictures Pictures Pictures!
As for going from a belt to chain drive usually that is the exact opposite of what people want to do.
And lastly a genuine comet belt!!! Expensive but you will blow through another half dozen belts if your not using a genuine comet!
Thepartsguy
The last time I checked was months ago. I could buy 6 belts for the price of this one single belt.
There is a reason 3 yak grease belts cost $19.99 and one genuine comet cost over $35
Ouch. “Ain’t got no oil in it”. I bet they ship the kart with just enough oil to coat the innards, probably engine assembly lube, and it gets on the dipstick so it looks copacetic to the befuddled new owner.
Seconded on pics and an engine autopsy would be fun. At least take it apart for assessment and spare parts. Might have just snapped the con rod..
tigeriron
My suspicion, they didn't check.
He said that it ran for 10 minutes.
After I got it home, the sump was DRY. So, I'm certain they didn't do a thing except put gas in it & fired it up.
He'd disassembled the clutch, and not much else. I wasn't going to look a gift horse in the mouth. I was happy tht my learning curve just cost me a few belts.
tigeriron
Dead engine sounds like a perfect time to open it up, learn how it works, and replace what broke if possible. Then buy some speed parts and put it back together.
I have it sitting here, for parts.
I've lubed it up. I will disassemble it, if salvageable, I'll make it run again. But for my needs, I'm looking at 2 cylinders for my next project.
tigeriron
I'll try that next.
I simply want as little slip as possible, and as much durability.
We're either in a super dusty environment, or ICE & SNOW.
When working properly ( and they almost always do ) the 30 series torque converter is as dependable as anything. They don't slip, and geared right offer great hill climbing ability as well as very good acceleration. Show us some pictures of what you're working with.
I guess this is your kart (although they keep changing the colors and features). I swear I’ve seen a grown man or lanky 9 foot teen driving one, it’s overpowered and can turn around in its own length by turning to full lock and stomping the brake. Plus his head sticks above the brush guard and he’s taking up most of the two person seat. All this to say that it can be a fun machine regardless of its 'child kart' status.
If you’re going to a Predator 670cc V-twin or something, that would be grand. :sifone:
tigeriron
Be careful playing in the snow or ice. You can cold seize the engine!
Well, I live in Western North Dakota.
I've yet to experience that. I've been through about 70 vehicles and only once did I have an unexpected exit of a connecting rod through a pan. It was a 4.9. A shocking way to go.... and the motor still runs.
I use 0w40 synthetic in EVERYTHING I own. But I don't own a 2-stroke, for which the throughput is different.
Plus, with the carb-air-cleaner sitting in a protected region, above the engine, I'm not really going to worry. There are a lot of snow machines & snow blowers used here. But when the temperatures are below -30, the only reason I'd be outside is because something needs shooting.
tigeriron
I'll make note of that.
I haven't moved images over, but I'll login with my mobile soon & send a few.
tigeriron
If you’re going to a Predator 670cc V-twin or something, that we it. I thinnk
Pretty much that.
I'm looking at the 30-Series clutches now, after th recommendation.
I'll consider other mods, to squeeze more speed out of it.
As for the next project, I'll share a few picks & take some input. I have a lot of "Before the cold arrives" projects right now, but I'm interested in learning more before I start sawing/welding & buying stuff.
Take photos of everything even if only for your own use. I’m fortunate to have saved the original craigslist photos/ads for 3/5ths of my projects, or maybe all, might have misplaced them in another folder. Great “befores” for the “after”
state.
We are a photo driven forum. Pics or it didn’t happen.
