Project Stoopid!
Are you sure the lack of grease isn’t causing the binding? Just a light coating on your balls when you assemble them may help you out!
( Puns and all innuendos implied. )
i’m sure. The opposite end works fine with dry balls!
Clearly the shop pixies have slipped in there and swapped some pieces around then. Better start setting traps.
Clearly!
A funny thing happened today at the Mountain Top Labs.
In the video is a glympse of our new (patented) counter rotating brake rotors!
the operational aspects of this device is still secret. But l can tell yathey wotk fantastic.
Greatly reduced torsional stress on the alxe for smooth effortless braking
You can preorder now! call for info. (Look it up) if ya have to ask how much, don't borher!
I noticed the brakes only counter rotate on one side. Is that normal. And you have too many wires. You need a weed eater to trim some of those wires back. Looks great otherwise with my good eye closed.
I'm not at liberty to discuss the counter rotation details. I can say that rate of counter is variable and adjusted by the driver To suit conditions.
