Anyone ever try an Affordable Bender?
Many I've seen where many folks use HREW on full-size, race car, roll cages :auto:
Also, FYI:
I got (1) of them "cheap" (~$100.00) Steel Tube Benders, a few years back
...but, the wise 'ol Chinese "goofballs" who made it, labeled, it a Pipe bender :huh:
Only the builder/operator can decide on what to use, obviously. We use whats we can afford, fits our needs and can be massaged into what we want with the tools/processes available to us.
I use DOM all the time, but i scored a bunch for scrap price.
We are mostly backyard fabricators,
without axcess to exotic materials and processes. Make a bad choice and ya will get an instant education! Most of us use the "it aint done til its overdone." principal. Nuthin wromg with that.
My $100 score:
But if the fabricator is asking for advice, rather give them solid advice to work with. End of the day, up to them what they get. Definitely not recommending people use conduit...think a few have on here.
Yeah well the plans were wrong so re-working them with the correct materials to better suit my needs, kind of got me on a bit of a kick. I think some of it was bad conversions from metric to standard and getting measurements mixed around when describing pipe and tubing.
Tubing benders do seem to be more expensive than pipe benders but they are not universal...not without modifications to making compromises. I remember poking around years ago when people said, the best way to avoid kinks while bending tubing would be to pack it full of sand and cap off then ends. Never tried it myself.
Sparkwizard
Richlands ,NC USA
I worked in muffler shops for quite a while. We always had that big, hydraulic bender in the middle of the shop and we used it every day. we could all bend custom pipes to go under a car pretty much by looking and estimating, then tweaking it after we tried to fit them .
We had dies for 1.5-3 inch exhaust TUBING. I tried bending other stuff, but no workie.
I bent a couple of benches, a picnic table and they lasted a long time, so I bought some 1.5 inch, 14 ga aluminized exhaust pipe and bent up a sand rail frame. Mid engine, seat behind the axle, solid front axle on a trailer leaf spring. Briggs V twin and a Peerless 5 speed with reverse.
It was slow, but it pulled a trailer full of gas, tools and chains to support the faster guys for over 4 years on some serios sand trails.
Wow, it looks kinda high tech and not the way I imagined. Kinda flimsy from this angle.
My thoughts exactly. I think the only tube benders I've seen were in muffler shops. The steel on that thing just doesn't look thick enough to handle real steel tubing. I wonder if in their Chinglish translation, they didn't mix up electrical conduit with tubing bender.
Sparkwizard
Richlands ,NC USA
Does anybody watch Carsandcameras on You Tube? They have what looks like an awesome bender that uses compressed air.
I don't recall seeing a name on it, but I will pay attention next time I see it.
I do most of the time. They have a Rogue Fab bender. Weld it yourself kit starts just under $800...requires a compressor to run.
AndreyStankotorg
Москва
Before I got a bender, I used a bandsaw and a MIG welder to miter quite a few offroad frames together using 1.5 inch mild steel square tubing. That was long time ago, and most are still being used.
Sparkwizard's bandsaw-and-weld method is still a practical way to get tight miters on 1.5 inch mild-steel square tube, including the straight and angled cuts a bender will not do. Dies follow the tube's actual OD, so a pipe bender is not a substitute once the plans have been converted to structural tube, as Kartorbust is doing.
A fine bimetal blade — about 10/14 variable pitch, or 14 tpi on thinner wall — keeps two or three teeth in each wall so the blade does not straddle the section and strip teeth. Support the tube so it cannot drop or twist as the cut breaks through, and do not crush the walls in the vice. Mark the cut on the side of the tube, not only the top, and check the first miter with a square before cutting the rest. A light feed on a new blade avoids ripping the set off the teeth; deburr inside and out before fit-up.
Disclosure: I'm from Stankotorg, a band saw blade supplier. If a short free handbook on organizing a saw-cutting station is useful, it is here: The Saw Cutting Department
DOI 10.5281/zenodo.23298145
Good info here
