Anyone ever try an Affordable Bender?
There's a company making tubing benders under the name Affordable Bender, kind of tempted to get one myself with 1" and 1 1/4" dies since that will be the most common sizes I'll be working with, maybe 1 1/2" as well just in case.
Each bender comes with 1 die for $399, but additional dies can be had looks like for $150 or so each. Uses a hydraulic bottle jack or something similar to bend the tubing.
Wondering if anyone on here has ever bought one or messed around d with them before.
Sparkwizard
Richlands ,NC USA
Looks like a fancy electrical conduit bender. I have never seen or tried one, but I have a Harbor Freight hydraulic bender. It is terrible. I bought a Vevor manual bender last year. I like it alot. I welded it to a hitch ball adapter so I can mount it to my truck. It takes some force, but it does a good job. I also added a 6 foot piece of 1 1/2 galvanized pipe to the original handle.
The body at least appears to be out of 1/4" plate. Conduit benders are not nearly as robust. I had thought about getting the rolling Harbor Freight tubing bender and doing the SWAG Offroad mods to it, but I don't know. Pro-tools and Rogue Fab are prohibitively expensive for hobbyists. Though the way my wife is talking, if this one goes well, she may want me to build a 2 seater.
I know ya'll know that tubing and pipe have different OD sizes, so this is a free public service announcement to remind ya'll to buy the right tool for the material ya wanna bend. Pipe and rigid conduit are the same OD and EMT (thin wall) conduit is another size.
Yer Welcome!
Well aware. That's why I have been spending time converting my buggy plans to proper dimensions and tubing. Plans called for black pipe to be used, which is completely wrong. So working on getting it done up for Drawn over mandrel (DOM) tubing for the cage and a-arms.
Affordable Bender = drinking at home
Yes, all the time.
Sparkwizard
Richlands ,NC USA
My neighbor has one of those HF tubing rollers. He seems to really like it. I have never seen it in use, but I have seen some thing he has made with it. He said it took some learning to use it. He builds some tow bars for ski boats and accessories for trailers. I might get one to try it.
Time to pay him a visit and ask for a demonstration. Bring some bender material...🍺
Hey Kartorbust,
Why do you consider black pipe to be "completely wrong" for constructing a go kart frame? :unsure:
Almost ALL of my (20+) custom karts are made outta plain 'ol water pipe (black pipe)
...& haven't had any issues (frame failures)
I agree "real" steel tube (as opposed to steel pipe) is structurally stronger
...&/also, much lighter, than steel pipe
But
Steel water pipe seems to be
...strong enough for use as go kart frames
...is a lot easier to source (ya can get it at most any hardware store...in the world)
...cost less (sometime 1/2 the cost of DOM tube)
...& is easier to "work with" for the average DIY'er (like, having thicker walls are easier to weld & not burn thru)
I'ma NOT tryin' ta give you a "hard time"...just wonderin' :innocent::devil2:
HREW tubing is plenty strong as well. While DOM is mo bedder, HREW is significantly le$$ mooola. I have built a few roll cages from HREW on some heavy pigs. They held up well to unintended field testing.
The end use of the vehicle is a big factor in material choice. A weld failure is far more likely than material failure, from my few years off road experience.
(‘specialy on my junk)
DOM comes with “peace of mind” while HREW will work just fine.
I’m not a fan of water pipe, but it works well for some.
Regardless of material choice, remember size DOES matter!
Pipe isn't structural and weighs more than tubing. The dimensions are also different with pipe being measured by inside diameter vs outside of tube. Pipe also isn't ment to flex, just ment to move a fluid or gas through it. ERW might be fine, but I don't want to compromise my safety and wellbeing on a cage made with a seam. The square tubing, I don't have much of a choice in that manner, but that should he fine, long as the seam is in the correct location.
Could be worse, could be dropping money on Docol R8 tubing or 4130 chromoly, at least price wise. R8 would be nice since it requores no pres-heat and is fine with wire feed welding.
Yup, I agree DOM & Chrome moly are the superior choices :thumbsup:
So, more like a "not the ideal" material
...as opposed to "completely wrong" ;)
Hey T,
Many I've seen where many folks use HREW on full-size, race car, roll cages :auto:
Also, FYI:
I got (1) of them "cheap" (~$100.00) Steel Tube Benders, a few years back
...but, the wise 'ol Chinese "goofballs" who made it, labeled, it a Pipe bender :huh:
It's shown & described in this thread (starting at post #34)
https://www.diygokarts.com/communit...ectrathon-racer-47-t-for-victory.48753/page-2
