Hack's Garage
Dang i cant get anything by you guys!
yeah,yeah, l know i need to pick up some plugs. Those are just temporary.
Hey T,
Just a thought
...but, instead of buyin' anything maybe...
Cut the lines off "flush" with the "heads" & then:
A.) Screw some appropriately sized bolts inta them :thumbsup:
or
B.) "Squirt" a dab of (fill in the blank) & smooth 'em off
...then, after the "filler material" dries, paint the whole unit (Satin Black for that factorylike finish) :2guns:
Cut them short and smash flat. Then solder em up.
Interestingly enough, those are sumkinda metricated flared pipe fitting thingy.
A 1/4 NPT plug fits nicely. I had one, needed four. The plugs are just to keep dirt out.
That is the valve thingy that sends hydraulic fluid to the "power steering" AKA hydraulic cylinder, with steering input. That is not used and was HACKED off!
Hey T,
Just a thought
or
That sounds like work! No way could i find the tools and materials to complete a complex task such as that in less time than a trip down to the village hardware store for plugs. The whole mess will be lost in a maze of tubing, suspension and other car stuff.
We was just sayin' ta save a trip & coin
Just "wack off" (that don't sound right...but, it is a technical term) the "jagged" line ends
...& "fill in" the holes
Sounds pretty simple
...& fully "hack" ta me :thumbsup:
...& fully "hack"
just being a lazy old geezer, with some disagreeable old f*** thrown in for fun!
actually i end up at the auto parts or hardware store at least once a weel. furtunately the two are nextdoor to each other!
I'm hijacking this thread to a new subject.
question for you electro geeks.
WTR you proby got a hack for dis.
That 420 Kawasaki from a few posts ago....
He got transplanted into the Nag cuz she was bad.
When the parts were harvested from the donor the voltage reg went missing.
So now l'm searching for a VR hack of some sort.
generic?
DIY?
midnight auto supply?
l only imagine the Kawasaki/Kubota VR is about as much a US Senator steals in a week!
Yeah, thats completely beyond the budget.
I shoud have given sum mo info. Le$$ than l expected but there is no harness to plug in to. I have one wire. What about the other 5?
Maybe an old school regulator? 3 wire in-out-reference?
Come awn! You might earn a Jr. Hack merit badge!
Just when ya thought it was safe we're back! The fucation is over and its time to get serious. Tryin to finish up the rear, axles, brakes, sprockets shocks and all that 'spensive stuff. The sprocket and chain should be here monday.
So while waitin took it all apart to cut keyways yada yada yada.
stay tuned for other exciting developments!
