Gy6 newly installed... challenge
Heavensview
Okay, maybe someone has an experience with.. on my new gy6 engine install.... the ONLY thing occurs when turning on ignition is the CDI buzzing loudly. Swap to another CDI and same result... been going through all wiring connections yet nothing... anybody thoughts of direction? Yes, the buzzing is from the CDI... there is NO strong strike coming from the solenoid.
EdwardWare
A CDI buzzing like that usually points to a power/ground issue or the CDI not getting the correct voltage. I’d check the battery voltage, grounds, and wiring polarity first. Also make sure the CDI type matches the stator (AC vs DC CDI), as a mismatch can cause strange behavior.
