МотоФинки для зимней рыбалки..
ЮРИЙ
Здравствуйте. Это мини транспорт для зимней рыбалки, простой и удобный. Сборка занимает, 5 минут, не более. Моторы прменяю, от бензо триммеров. Редутор 5:1, шестернння ведущая 11 зубов, ведомая 74 зуба, цепь t8f.
Hello. This is a mini ice fishing vehicle, simple and convenient. Assembly takes no more than 5 minutes. I use motors from gas trimmers. The gear ratio is 5:1, the drive gear is 11 teeth, the driven gear is 74 teeth, and the chain is T8F.
Translated.
Hello. This is a mini transport for winter fishing, simple and convenient. Assembly takes no more than 5 minutes. I change the engines from petrol trimmers. Gearbox 5:1, drive gear 11 teeth, driven gear 74 teeth, chain t8f.
JimD
Naperville, IL
Direct drive Denny, so you better be ready to go when you pull start. He sure kept the complete unit light, there is no extra weight there, they use the K.I.S.S. principal over there also.
Wonder if it has a weed whacker clutch. Looks to be the housing for one.
JimD
Naperville, IL
Ed -- we might have to send Denny over there to check that out. You made me look again and you are right that extension on the engine may be a a clutch housing. And I looked at the sprocket again and wonder if that is being held in place with a set screw since the 6 star shaft is not drilled and tapped. He sure saved a ton of money because a snowmobile today is what a car cost 20 years ago but i am old and still remember .23 cent gas. We could fill up and drive into Chicago for a buck.
Keep It Simple Stupid!
ЮРИЙ
Денни, у него прямой привод, поэтому будьте готовы к работе, когда будете заводить. Он, конечно, постарался сделать весь агрегат лёгким, лишнего веса там нет, они и там используют принцип KISS (Keep It Simple, Stupid — Делай проще, дурак)
Сцепление автомат, даёшь обороты - оно работает. Есть много видео, но не могу здесь вставить.
It's an automatic centrifugal clutch. When you give it gas (rev the engine), it engages and works. There are many videos of this, but I can't insert them here."
translated
This has more features than the one in your introduction, Yuri. Is the wooden platform in front a place to carry cargo (basket of fish?) or is it a seat for a passenger?
I really like the studded tire. Nuts and bolts, not nails. 😎
Keep. It. Simple. Stupid., in case Yuri was wondering. Question for the forum: Is the Stupid part an insult or is it “Simple-Stupid” as in so simple it is stupid, or stupidly simple? Complex then would mean intelligent. Nevermind. 😏
I always took it as.........just keep it simple, don't over think or complicate it more then it should be. The stupid just finishes the acronym. Or I just might be stupid. 😂
Looks like you need to keep it simple........
ЮРИЙ
Представлю вам ещё одну самоделку. Она для езды летом или зимой. Летний вариант с рулевой колонкой, для зимы лыжи. Просто снимите рулевую колонку и закрепите лыжный модуль.
