Steering is super floaty and unstable. Looking for advice.
DuckSoup
Good morning!
So I've been working on this GoKart that I picked up dirt cheap a while back just as a fun side project.
I've got it fully working again and have made a lot of improvements to it but one of the areas that I'm working on now is the steering.
When you steer this thing it is very unstable and has a ton of play from the steering wheel to the wheels.
What I noticed is that the spindles look to have an additional attachment that was welded on and I don't exactly know what the previous owners were doing here.
I'm trying to remove all of this extra play but is it better for me to just completely replace the spindles but keep the existing bracket?
I guess I'm not sure what's going on here and looking for some advice. I attached some pictures and a video.
Howdy & :welcome2: DS,
Looks like you have a "double pivot" situation
The "stud" has a pivot
...& the tie rod end does too
You only need (1) pivot
...either on the "stud"
...or on the rod end
I would remove the "stud"
...& just install a nut-n-bolt
...thru the hole the stud was in
...& the rod end
That should remove most of that "play"
...& work much better :cheers2:
Functional Artist explained it super well. But I must say, Bubba (the half-witted previous owner) strikes again! I’ve never seen a double ball joint steering setup before. Wild. 🤯 Maybe it was designed to simulate drunk driving or something? 🤔
Cut off and discard the lower ball joint/tie rod end assembly that’s welded to the spindle arm, and make sure there’s a hole there for a bolt, preferably a shoulder bolt with a smooth, non-threaded portion. Use the style of tie rod end (aka Heim Joint) that is on the top, much better than the style that is on the bottom. Just do what FA said.
Here’s an illustration of a Manco 297 front-end. Parts 26 and 27 are Nut, 3/8-16 Toplock and Bolt, 3/8-16 x 1.50” respectively. Just throwing the hardware sizes out there because your existing tie-rod end may have a 3/8” bore as well.
[ Click to embiggen ]
Sparkwizard
Richlands ,NC USA
That looks like a tie rod end welded to the spindle. It can be removed with some cutting and grinding, but, honestly, I think I would replace the spindles and keep the Heim joints on your tie rods.
just wanted to make sure I wasn't crazy!
Just keep telling yourself that, despite the fact that you’re in the DIYGK asylum with the rest of us.
I looked at it again, and Bubba sure welded it up pretty good. Might be hard to get a cut-off wheel in there to get it loose from the spindle arm, unless it’s a small diameter one 2” or so. But anything is possible, utilizing some patience on the parts you have to make them look nice.
Cut where the green line is and go around the other side and be sure to keep the heim joint that’s on top, that’s a high quality ‘deluxe’ type. The other kind on the bottom has a fancy rubber seal but it’s easy to lube the ‘deluxe’ style, just put a drop of oil at the red arrow and voila.
I see bright metal marks on the spindle arm but don’t know what he did. I’m with you, Grizzly, I want details on the procedure.
:popcorn:
I tell ya, it steers a whole hell of a lot better now!
I see a little slop in the heim joint at the spindle when you turn it to full lock in either direction. The bolt looks like it is too small for the socket in the joint. It should fit tightly. Check the joint at the steering shaft too. Don’t forget to add a little toe-in for alignment.
