Hello everyone, I am a chain manufacturer.
Howdy Gena,
Q: What would you advise in this "chain drive issue" scenario?
"Here's what problem I keep running into with a drifter kart:
I have a 224cc Predator engine, live axle, 30 series torque converter (1 new out of the box), 72T sprocket, 10T jackshaft sprocket and a #35 chain.
I can't keep the chain from coming off. I have tried running with it loose, snug tight and every position between both extremes"
(DFW Realist)
Gena
Howdy Gena,
(DFW Realist)
Howdy,
This is usually caused by sprocket alignment, axle wobble, or engine plate movement — not just chain tension.
I’d recommend checking:
1.Alignment between the 10T and 72T sprockets
2.Rear sprocket or axle runout/wobble
3. Chain slack (about 1/2" play is usually good)
4.Engine/Torque converter movement under loa
