Time for another off topic rant
Atlanta, GA
Ok guys, we have a 2013 Cadillac ATS, 2.5L non-turbo RWD in the driveway with an A/C system that doesn't want to keep the trophy wife cool. This, literally, is not cool. So, the compressor, condenser and that other little thing have to be replaced. "So what?" you ask. Well the vehicle has a couple other qualities that have just become glaring "WTF" questions that I wanted to share.
1) The transmission uses the radiator as a cooling source, there are two lines that run into the radiator top and bottom on the driver's side. Obviously to remove the radiator, one will have to pull out those lines, which may lead to some loss of trans fluid. Ok, so we'll just replace the trans fluid through the dipstick tube ...whaaat? There is no dipstick tube. Down on the transmission there is a rubber plug where the dipstick tube would and should be. It is plain as day there could, would and should be a tube to allow maintenance of this fluid, but there is not. Who what how stupid???
2) The condenser lives in front of the radiator. The radiator is held in place by a part rubber, part plastic shroud that wraps from the upper left corner of the radiator down around and forward to the bumper and back up to the upper right corner of the radiator. Imagine a large square tube with no top |__| Removal of this shroud is required to remove the condenser, as it resides inside of it. Removing the shroud requires you remove the front bumper cover entirely. As in remove the front of the car. It's the 21st century now, can we not think these things through before we build machines that are virtually impossible to maintain?
I'm sure many of you have experiences that make mine pale in comparison, but da##it man, come on! Thank you for your attention to this matter.
Thepartsguy
Well the engineers don’t have to fix it in the field themselves so **** whoever has that job. Make it only good enough to last a few years so they toss it and buy another.
This is not communist fault this is communist feature…
As someone who builds brand new vehicles for a living, I would never buy one new. Sure, all the stuff you are rightly b!tching about, but more importantly the fact that any vehicle built after at least 2014 has a bunch of computers(expensive) for all these stupid innovations we enjoy to keep us comfortable and entertained while we drive from point A to point B in luxury. I'm guilty, I lease a new vehicle for wife every 2-3 years so she has a reliable vehicle and no repair costs to us(other than always having a vehicle payment :ROFLMAO: ) but I drive an old Chevy Silverado Z71 that I can maintain and easily work on if I have to. She's a girly girl who couldn't change a tire if she tried. They got us by the balls, man!
caseysct200u
burn them fk!ng tires to the rim!!
i have a very simple slution.....dont buy a new car just buy like a 1986 toyota spifily look for the non american made ones look for the japananese made ones
there litry unstopble(besides a nuke)
caseysct200u
Stay in school.
yea i will
well i found out what happens
whe you put straight gas in a
2stroke......it fking explodes
and my legs nearly died
i so StUpId
i thought i grabed the 2stroke can.....well i didnt
Atlanta, GA
Hijack all you want, it's entertaining. The compressor is not doing the work. It comes on and stays on working hard, but hardly working. I figure I have to pull it mostly apart anyway, and I can get all 3 replacement parts for the price of one. We got the car for free from my wife's aunt, less than 40K miles on it. I am not opposed to having DIY automotive repair adventure time.
Generally, removing the whole front clip isn't that hard, just really annoying. Trans cooler tied into the radiator is pretty common now across a lot of brands. You might lose less than a cup of fluid. In a transmission that holds 8+ quarts including the torque converter, not much to worry about right away.
About two weeks ago, I had to replace the compressor and condenser/dryer on a 2019 Mercedes Sprinter 3L V6 diesel. Bearing decided it wanted to no longer be seated properly and the compressor grenaded a hole out the bottom of the case.
Right now, I'm an hour in to a 9.5 hour job of replacing a heater core in a 2022 Ram 1500 DT body style because it decided to leak in the vehicle. Coolant was pooling on the passenger floor mat, as well as under the center console.
While modern vehicles are kind of nice, the simplicity of older vehicles is nicer. Older Fords had the A/C evaporator under the hood and not behind the dash. Whoever designs modern vehicles, needs to stand in a puddle and back probe the orange wires under a hybrid or electric vehicle.
Its all about manfacturing for profit.
Period.
Why bother inspecting a million crankshafts.
Daughter had one of GM6.2 grenade on her.
Then chevrolet shyt on her. She nuw drives a cummins.
I'm kind of hoping the Slate vehicle does well. But with the body being made from polycarbonate, I don't know how well that will hold up long term.
Thepartsguy
Period.
Removed the tire inner fender the engine mount and stabilizer bar in a foot of mud to get the starter on a sorento.
Move it or it’s getting towed type situation. They said let it get towed.… They were jumping up and down when I had the engine dropped back down onto the mount and it all back together. started right up.
Like I had just did the impossible but in reality it was just me and like 3 floor jacks in the mud doing sketchy **** until It worked or someone gets hurt.
