- Messages
- 2,874
- Reaction score
- 3,888
I like the swing arm you posted. Should be square and ridged. The engine plate that is on it looks like it is for a small block. 196 to 224cc. It might also be a little on the thin side to withstand the weight of the 420. I purchased a big block mounting plate to put on my Manco Intruder kart. It is 1/4" thick steel and rolled at the edges for additional rigidity. It needed every bit. Once you get moving and bouncing around a bit, A standard 1/8" plate ( I believe that is the thickness ) is going to flex a bunch. The 420 weighs more than double of a small block.
