Hack's Garage
Im sure you know this.
The spacing between the bolts (red) should be the same for both sides and at the same angle, parallel.
Same for your control arms. And CV shaft. (Blue).
Your CV knuckles should be aligned with the red line.
Flip your hub contraption so the axle line is dropped if you can. Lower the tire for greater ground clearance.
Nice work though. Suspension geometry can be tricky.
I probably did at one time. Not any longer.
Lotsa stuff has gone missing.
its a new adventure everyday!
Thats why l try to keep my head in the game!
The game lately is tiddly-winks, but its still a game!
The hub contraption has been reworked, the CV shaft is were it should be. (Still in the box)
The whole contraption works mo bedder. Pics tomorrow. I'm burned out.
Gunna put my feet up and sip some Pendelton.
In other exciting news, work continues here @ MTL. This weekend past saw 3 major milestones...
The radiator catch bottle. After days of searching for the correct bottle, I have up and sourced one locally.
The bottle had to meet certain design factors, be unbreakable, visually appealing, and make a statement.
There is only one real choice. This is a temporary bottle as the desired one is currently unavailable. The temporary was chosen 'cuz it has the same shape and dimensions as the chosen one. Update to follow when necessary.
Daughter #1 insisted on painting in the smiley Yamaha man. So the was given free license.
Started trying to figure out the shift lever/cable/transmission thingy...
Atlanta, GA
Not just canadian, but artificially flavored too. Yikes. And less than 80 proof! I'd rather drink beer.
Did you show Daughter #1 that the face is actually a Stormtrooper?
OK don't' be a whiskey snob!
I reluctantly used that bottle, knowing the grief that would follow. That is actually Purdy good, for slummin round.
My go to is XO and the TEMPORARY bottle will be replaced!
Shees, tough crowd!
I am a whiskey snob. :LOL: Crown Royal Black is actually pretty good. XO is ok. Crown is kinda bourbon, but it's not because it isn't made in 'Merica.
Anywho, sorry to derail this awesome project with my whiskey snobbery........
Ha! Yep. Same reason Jack Daniels isn't "bourbon". My standards in my older age is whiskey is bland unless it is at least 90 proof or higher. There is nothing really serious about me, sometimes to my fault. :ROFLMAO: Cheers brother!!!!:cheers2:
Meanwhile back at the mountain top....
just dinking around with little stuff last coupla days.
todays project was the hand brake. Had to form a hose or two. It occured to me,
Maybe summa the youngsters here have not exprienced the satisfaction of perfectly formed hoses?
Use shrink tubing, its simple, easy, and fun!
Stay tuned for amazing tips and tricks, that ya knew and forgot!
