Carburetor Jets
Staff Murderator
Are you using that flexible fuel line that turns rock hard after you use it?
Is there any that doesn’t? I’ve been doing my part (non ethanol fuel) but this “quality” OEM type fuel line is rock hard after 1 duty cycle. Oregon brand, 1/4” ID, blah blah…
Any automotive grade fuel line doesnt turn this hard. I mean its hard to the point of being brittle. If you bend it, it completely snaps. Never noticed this poor of quality anywhere, until just about 3-4 years ago.
65ShelbyClone
SoCal
If I had to guess, it would be that the cheap hose in question is probably regular nitrile rubber and not HNBR or Viton like it should be for fuel exposure. It may not even meet the spec to be considered actual nitrile; it is China after all.
The OEM hose stock for carbureted dirtbikes is pretty good, at least with the Hondas I'm familiar with. It's fairly thin-walled with no fiber reinforcement, is very flexible, and lasts for years.
EDIT: And yes, that little 19 or 20mm carb is too small for a 301. It will still run just fine with proper tuning, though.
