idk ct200u wont start after mods
l’m with you, I definitely think there’s not enough fuel going to it. There’s never enough fuel for my liking! 😄
ok so I got a https://www.ombwarehouse.com/perfor...orque-converter-kit-for-ct200u-ex-bt200x.html for my cloeman ct200u and I'm thinking there's not enough fule going to it was curious if y'all thought the same
Does the factory choke still exist? These newfangled engines are designed to run super lean and it may not start EVER without a choke. Maybe it's the nature of newer carburetors regardless of the new jet.
Did the bike run before you added the Stage 1 kit? Don't laugh, you'd be surprised how many buy a minibike brand new, never run it and make haste to add a super duper Stage 1.
Is the kill switch on/activated or faulty? Could be a simple no spark issue.
Will it fire up on a squirt of starting fluid?
Is the spark plug wet after several attempts at starting it?
caseysct200u
burn them fk!ng tires to the rim!!
yes it did run before the mods. but now it runs but I only for a few seconds on starting fluid
Did you put a new carb on it? It looks like that kit came with one. Is it the same as the stock one?
Did all the linkage get put back on correctly?
I would assume it was shipped to be close to "running" settings, but any carb will need tweaking to work for your setup.
Are you getting gas in the cylinder?
Is the plug getting wet?
caseysct200u
yea i put the knew one on but it wouldn't start so I'm putting the old one back on to see if it will run
yes I put the linkage on correctly
i don't know what the carb was set to I'm gonna put the other jet in it and see if it will run
and no I'm not getting gas in the cylinder
and the plug has some oil on it
Did you put the plastic gizmo ( sorry, I forgot what it's called ) that goes between the head and the carburater back on? With the stock style carburetor they will not run without it. Also very easy to get the paper gasket oriented wrong. The holes and little voids have to be in the right place. Also with the fuel valve open, pull the drain plug ( it's the one on the fuel bowl that sits on an angle ) and gas should freely run out of it.
caseysct200u
ohhhh I should try that as well thanks man
caseysct200u
im gonna try and see if the jet it came with whould help all the other guys I've seen with this setup has added the jet that came with it
Hurry up and fix it, this very simple engine is kicking your butt! Don't let it win. 😁
4-Cycles of operation:
1. Suck
2. Squeeze
3. Bang
4. Blow
4 Things you need:
A. Air
B. Fuel
C. Compression
D. Spark
*All at the proper timing
EDIT: fixed it with some explanation. Got to keep the kiddies pure minded.
caseysct200u
when I read the first part I'm like what...........? ohhhh hese talking about the engine
caseysct200u
well after I get home I'll put my fuel line on cuz it got cut so yea then I'll do the adjustments
caseysct200u
ok soooooo I put the jet in it and my dumb :censored:just released the......................gas was off but hey we then switched it back to the old jet and it runs "better ish"
Who’s the stupid guy now? It ain’t your friend no mo’.
:roflol:
