Broch 2 new keyways and mill the shaft to match
No broach unfortunately. But yeah that would be an easy repair.
l'll have to resort to desperate measures...
Fill the keyway with weld and file in a new one I bet! I would.
File? Thats like work, that aint happening.
So l have had to pull out the seceret weapon a couple of times with great success.
l was going to get some pics, but after wrestlling with this thing for an hour, the pics got skipped
So who sez a key/keyway has to be square? Round works also, and no broach needed.
in this case i enlarged the key to 5/16 and made it round!
how?
Ya need a ball end mill to run down the "shaft".
There has to be a tight fit or this won't work. So run the ball end mill down the male part, but only as deep as 1/2 the diameter of the key. The key here is a 5/16 dowell pin.
inside diameter of the female part (the ramp thingy) use the same end mill and make a half round keyway, also half the depthof the key.
5/16 key so the depth of the slot on each half should be 5/32. (.3125 & .1562)
If done right the pin should have an interferance fit.
If none of that makes sense, just accept it as the nonsensecal rambling of a lunatic mind...
