Adding Lights to Our Yard Kart
pjoe
Gonna do some night karting. Purchased a light bar, two spotlights, some strip LEDs, a battery tray and a four gang switch set. Kill switch will be one of the 4 switches. All powered by 12V. Can you folks post some pictures of your lighting setup? Can you suggest a battery/charger setup that'll give a couple hours of lighting? Engine is HF Predator 212, we do not have an alternator.
Thank you
We…have…the technology. Lighting coils on small engines. They had them aplenty on early minibikes and due to those lights and legit transportation features they were used as legit transportation (licensed as scooters) but I digress.
Some people have retrofitted the alternator and flywheel from a lighted Baja/Coleman 196cc minibike or similar and put it on a Predator but it can’t be that easy. The issue is does it have the same taper on the crank?
With LED tech I am less concerned about battery duration. Just make sure your battery has a hefty milliamp hour rating.
pjoe
I agree
Sparkwizard
Richlands ,NC USA
You could mount a pulley on your axle, run a belt to an alternator. It would only charge while moving.
Small deep cycle batteries can be had, and you should go very conservative on your amp draw. You do not need to try lighting the whole neighborhood.
I don’t even know what one of those are. Can you post some pics of your purchases, I really like seeing what others buy? If not photos, Amazon links?
That’s a great idea and it brings to mind the older lawn tractors (and other equipment) that used a belt driven alternator/generator that ran off a pulley mounted to the flywheel. Problem is, those may have been electric start only and it would be a real challenge to have an external pulley where the recoil starter assembly is on a modern engine. The really old engines had a legitimate *rope starter* there which was where you wound a length of rope (clothesline really) around a pulley that had a notch in it (for the knot on the end of the rope). It begs the question whether those rope pulleys were large enough to hold a V-belt…
An automotive style 12V alternator would be a real humdinger and I imagine it would be really effective in the application.
Pulley on axle would do nicely but one on the crankshaft/PTO would do nicer. You’d need a longer than average PTO though to handle clutch/CVT and pulley….🤔
Just a panel that holds 4 switches.
Oh great, now I won‘t get to see the stuff :mad2: :censored::surrender::cornut:
pjoe
GPS (and others) sell a two coil charge coil harness and a flywheel with two magnets that replace the standard flywheel on a Predator 212 engine. Connected to a solid state voltage regulator (also available from GPS), it generates 12V to keep your battery charged. I'm ready to pull the trigger on this, has anyone else?
Didn't know GPS had that in their inventory. Better buy it impulsively, :thumbsup::thumbsup:
With enough stupidi.... ERRR... I mean creativity. It can be done. Not recommended for children over 50.
Pay no attention to all the other crap attached to the engine. Not for real kart use, experimental use only. It did win the $100 bet however.
Totally different suggestion :cornut:
...maybe leave the engine & "drive train" alone
...& just use a 12V lithium power tool battery, to "power" the lights on your kart ;)
Could have extras "on board" for longer rides
...& just re-charge 'em overnight, in the garage :cheers2:
No you are steering the convo back to the original very simple and easy premise: Battery and lights. I’d want the most absolute efficiency from the LEDs and the battery just because losing your lights in the middle of a night run can be disheartening. So, less lights, more battery.
I just think we went backwards to the “easy route” and the established norm of engines with alternators like your riding lawnmower with headlights.
