Purpose of brake band clip?
pjoe
I'm restoring a Manco 415 kart missing many pieces of the drive wheel setup. What is the purpose of the brake band clip on a 4" brake band for a Manco Kart? I'm guessing that it keeps the band centered on the brake drum. Many of the videos I see show the brake drum mounted flush to the sprocket, which would cause the clip to rub against it. Can I just grind off that side of the clip? Also, should the band be mounted with the clip side up or down, or does it matter?
Haven't bought the motor yet, but most likely The HF Predator 212. Once I put the clutch on and mount the engine, I'll probably figure out all the correct spacing for the drum and sprocket.
Thanks
JimD
Naperville, IL
You are correct, the clip is for centering the band on the brake drum and is not really needed especially if the brake drum is flush against the sprocket. Just look at the above picture and put in your band the same way. You should have a strong return spring to return the pedal to a neutral position so there is no constant pressure of the band on the brake drum.
pjoe
Thanks for the help Jim. Yes, the return spring is on order. Can you send me the .pdf that you got that image from?
I think he got it from here: https://www.gokartsupply.com/415parts.htm
Otherwise this one is better, but I am guessing at your particular 415 (there are several variations):
Edited to add: Guess they call it "brake band with retainer" --
