- Messages
- 2,984
- Reaction score
- 4,038
Best ( and probably ) the only home made pedals I have ever seen. Burning that midnight oil stuff really paid off. It looks great.
Midnight oil, hasheesh, it’s all the same thing.Best ( and probably ) the only home made pedals I have ever seen. Burning that midnight oil stuff really paid off. It looks great.
OH BOY do I have something for you!! Let me dig through my pictures real quick here......Best ( and probably ) the only home made pedals I have ever seen..
All that just to flush your toilet and put down the seat?OH BOY do I have something for you!! Let me dig through my pictures real quick here......
Home-made pedals you say? LOL!
My old sim pedals. Theyre not the hunk of crap they look to be.I'm really not sure WHAT that contraption is. Way to complicated!
I did not understand a word you said. And I’m ok with that!My old sim pedals. Theyre not the hunk of crap they look to be.
The door closer on the brake houses a 200kg loadcell. Clutch houses an arrangement of dry lubed elastomers and springs to simulate a digressive feel. The throttle was measured right from the TPS, not the one that came on the throttle body. Vibration motors and bass shakers to simulate different haptics. Seating position, pedal travel and degree of rotation, pressures needed to fully depress made to match my 300zx.
Sadly I had to ditch those and upgrade to a more 'professional' grade of pedals. Well, a copy of a professional set...
Sorry to steer this off topic so much, ill leave it now.
That is a real road, l drive a real car onnit. That as sim as l get.I just drive real cars, mini bikes and gokarts
Why can’t you use the in tank fuel pump? You need to build a fuel tank anyway, just make the fuel pump fit it. It’s a lot cheaper than buying a high pressure pump. And all the components will be compatible too ( lines and regulator). Let that inner cheapskate back out there buddy!Meanwhile back in the Lab...
So this donor has EFI, which is way cool. A long time ago in a galaxy far far away I screwed with throttle body injection.
I recall vaguely the fuel pressure to be somewhat more than carbs. That brings up the question. What is the operation fuel pressure of a Yamaha EFI system? There is an in tank fuel pump that I can no longer use. I need to find a suitable pump for the transplant.
WTR?
Thats the plan, but the fuel pump is mounted on a 3 inch round plate/plug that is held in place on the bottom of the gas tank by 8 screws and a rubber gasket. It just reeks of trouble like leaks. I won't tolerate any fuel leak no matter how small. I hope to use a regular 'ol fuel cell. Cutting a 3 inch hole in it....don't think so.Im with Denny, try to reuse as much as possible. It all ran as is. just transplant it all
