Jamie P
I figured I'd start my first build thread. I've been watching you guys post stuff for years, and I've been messing with this project off and on for a while.
Years ago I had a real 1933 Ford pickup that I started to turn into a hot rod, with the help of my father. I didn't get far and sold the project. Now I regret that decision, and the real deal is too expensive to build. I guess that's why I'm building a mini version. I figure I'll take it to car shows with my dad when he shows his hot rod woodie. It will be something fun for the kids to look at. Really, I have no idea why I do these things. I guess it's fun to see what I can create when I put my mind to it.
These 10 photos show the progression of the project from the infancy of the idea to how it looks now. I started by making a cardboard and joint compound original cab then made a 6-part mold of it. I honestly had no idea if it was going to work, but I was able to successfully cast a fiberglass cab. It wasn't perfect, but after some rough bodywork it looked passable.
Since I was able to cast a cab, I moved on to the next step, which was building the frame. The shape and look of the frame is critical to these pickups, with all its curves and bends. A normal, tubular frame would have taken 1/10th of the time that this took to build, but it wouldn't have looked right.
The next step was to turn it into a rolling chassis, which I've nearly completed. I had a hiccup with one front tire, which I'll explain in another post. At this point I think I'm going to push pause on this project to focus on the Sears (Manco) kart that you can see in the background for scale. That one will take less time to complete vs what's left on the pickup. I'd like to have something that actually drives for next spring.
The last photo shows an ugly cartoon of the remaining steps, because you're probably wondering how the heck does a person drive this. The steering column will enter through the firewall, turn at a u-joint, and exit through the roof with a handlebar with twist throttle and hand brake. The driver will sit above the engine in the back, on a minibike seat, and the driver's feet will rest on foot pegs at the center of the frame rails. I'm 99.9% sure I'll need a wheelie bar as well because most of the weight is located just in front of the rear axle.
Next steps include fabricating a bed, a frame for the seat, a grille shell and hood, steering, and completing bodywork.
I'm not a professional welder or bodyman, so please take it easy on my workmanship, but I welcome technical advice and thoughts on the mechanical side of things. I'm learning as I go. Building something presentable out of a pile of thrown away junk is new territory for me. It's rewarding and fun... except for the mess from fiberglass. I'm not doing anymore fiberglass after this project!
We like cars too!
