Help!
WutsHeh
Hey all! I recently received a Tecumseh 5.5 Horse engine, and the shaft on it steps up from 5/8 diameter to 3/4 diameter, with a 3/16 key way. I believe it was keyed and tapped for a pulley. Is there any clutch I could put on this thing? The frame I’m putting it on is a one wheel peel, with a sprocket to fit a #35 chain. PLEASE HELP
You could “sleeve it” with some tubing to bring the outer portion of the shaft up to the same diameter as the rest of it but the problem is the short keyway. You need a normal, full length keyway to key a clutch to the shaft.
Good on you for using a Tecumseh. However, to keep using it I see a replacement crankshaft in your future 🔮
You might find one nearly anywhere even fleabay if you know what you’re looking for.
What is the model number/engine code of your engine?
WutsHeh
The model number is: LH195SP-67516D
WutsHeh
Do you think a smaller made pulley clutch would be the best bet then? If I did that I would have to replace the sprocket with some kind of pulley too then. I’m not even sure where to look for a pulley that would hook up to the side of the tire like the sprocket does.
V belts and matching type pulleys don't drive karts very well.
Use a Centrifugal Clutch and chain for the simple little tire karts.
A better idea is a Torque Convertor like a comet 30 series.
I think at the least, your crank could be sleeved on the 5/8" portion but the rest of the crank needs to be broached for a keyway [as well as the sleeve, probably (a split sleeve)]. Otherwise, you're going to have to determine which engine in the LH195 series has a straight 3/4", all-one-diameter crankshaft and get it. Er, at least all-one-diameter for the part of the crank that is outside the block.
Parts lookup for "LH195SP"
https://www.partstree.com/search/?type=model&term=LH195SP
Click on an engine, scroll to part number 30 [crankshaft] and see if you can find photos for what these actually look like. 😫😰 FUN!
Atlanta, GA
Or maybe something like this:
Perfect, "parts right off the shelf" as it were. Now about that keyway.... I say he might need to extend it if just a little or a lot. The crankshaft steel should be pretty hardened beyond mild steel, but Mr. Abrasive Cut-Off is stronger. How feasible is it to cut more of a keyway with a hand held tool?
I think he should be shopping for a clutch first and most clutches I have seen only have a short key on the inside of the bore. Decisions, decisions....
Theoretical outcome:
I just realized that shaft is looooong. Perhaps too long for a simple centrifugal clutch. How long is it from the side of the engine to the end [minus the bolt and washer], WutsHeh?
You might hacksaw 🪚 the "deformed" end off and then some more.
WutsHeh
I actually thought about taking a cutting wheel to the 5/8 bit, and cutting the key way back some. I paint pretty often so I believe I’d have a steady enough hand 😂 and it’s 3 3/8 long. Pretty freakin long lol
The 212cc Rotaderp has a shaft that is 2.43 inches long which is plenty long for our applications and uses. With a longer shaft like yours, it's a liability having an "appliance" further out on the shaft -- you want the clutch mounted as close to the centerline of the crankshaft as possible.
Agreed on cutting off the 5/8" portion but you could cut it down to size [2.5"] and have the bulk of the exposed crankshaft [sometimes called a PTO] cut for a longer keyway. Plus you may need the end drilled and tapped deeper as that bolt and washer is crucial to clutch retention.
I'd take your engine apart, take the crankshaft to a local machine shop and get an estimate for those services. Shouldn't be too costly, I am guessing.
