I need some help with this
Jimmyjoe
I got this race kart frame and painted it, and I also have an axle for it, but the mounting plate goes where the bearing mounts are, and it gets in the way. What should I do? And I'm also not sure what to do for the brake situation because I don't have a welder yetView attachment 154081View attachment 154082
Don’t know if you do eBay, They have decent welding machines for a hundred in a half. The one I have is a toolium. Has gas less wire fed or the option to apply gas and the wand capable to do both , tig welding, and stick. One year later no problems with the correct rod. Self t thought I love it. Get you a good hood. Hobart creator self darling a bout another hundred a year a go no problem just batteries needed changing dollar store about two bucks
Jimmyjoe
Pic above same set up with the axel. That kart will do 52 mph with no internal engine modifications
