American Ethos (2025) Electrathon America Racer
America "seems" to be coming BACK
...& this has inspired...me :thumbsup:
As such...I'ma gonna call this one American Ethos :wai:
American ethos refers to the unique character of American institutions and the distinct national identity of the American people.
It encompasses the moral ideas and attitudes that are associated with American society.
My "left brain" started workin' on another project :innocent::devil2:
So, I rounded up some parts
...& arranged 'em
Maybe...something like this? :unsure:
* Notice the "Driver Safety Cell"?
...with its "I'll bust thru your wall...PUNK"...look :2guns:
So it’s going to be gasoline powered? Because America runs on gasoline! :cheers2: Well, and beer too. Real Americans need beer too. And whiskey lots of whiskey. Preferably home brewed, with real spring water. I got to stop now I’m getting thirsty. :D
Hey Denny,
Um...NO :(
It's gonna be a "unique" Electrathon America Race Car
...& will be designed, to comply with Electrathon America rules ;)
If its 'merican is there a recall for engine "failure"?
where the "vehicle could lose proplusion"?
wait, diamonite isn't done!
Hey T,
Diamonite is still "in the que"
...next step is fiberglassin' the monocoque/body :thumbsup:
This spring has been unseasonably cool (chilly for doin' fiberglassin')
So, I have just been waitin' :popcorn:
While a waitin', "new" ideas start "poppin' in my head"
...& suddenly...we are...here :unsure:
What are the Sway Bar Bushings for? (someone may ask) :unsure:
The Sway Bar Bushings will be used as "hinges" for the "suspended" Nacelles or Outriggers :thumbsup:
Nacelle
A nacelle (/nəˈsɛl/ nə-SEL) is a streamlined container for aircraft parts such as engines, fuel or equipment.[1] When attached entirely outside the airframe, it is sometimes called a pod, in which case it is attached with a pylon or strut and the engine is known as a podded engine.[2] In some cases—for instance in the typical "Farman" type "pusher" aircraft, or the World War II-era P-38 Lightning or SAAB J21—an aircraft cockpit may also be housed in a nacelle, rather than in a conventional fuselage.
Outriggers
An outrigger is a projecting structure on a boat, with specific meaning depending on types of vessel. Outriggers may also refer to legs on a wheeled vehicle that are folded out when it needs stabilization, for example on a crane that lifts heavy loads.
Yup, for the ISS (Independent Side Suspension) :2guns:
The "plan" (so far) is to have an independent motor & brake...system
...kinda centrally located
...on each side of the racer :thumbsup:
With independent hand controls (for motor & brake)
...instead of a conventional steering system ;)
Kinda like these karts (Zero & Land Speeder)
...but, (hopefully) better designed & balanced :thumbsup:
Zero
Land Speeder
Each Nacelle (or outrigger) has to
...support, that side of the chassis
..."hold" the chassis at the "right" height
...& be independent of each other
Plus, they also need to be a base or mount, for
...the wheel
...the motor
...the coil-over shock
...& the brake system
FYI: I'ma usin' some
1.) 10g. steel plate (a little thicker than 1/8") as the "base", for the nacelles
2.) a 2" wide x 1/8" thick U-shaped mount, for the axle mounting bracket
3.) a piece of 1/2" Schedule 40 water pipe (~7/8" OD x ~5/8" ID with a ~1/8" thick wall) for axle replicability & re-enforcement
4.) a piece of 5/8" solid steel rod (as the axle...itself)
A 48V 1,000W brushed electric motor will be mounted on the top of the "base plate"
...protected in-between the (2) "main" frame rails & behind the wheel
...& the brake mounting bracket is to be mounted below
The Sway Bar Bushings will be used as shock absorbing "hinges" to mount the Nacelles to the chassis ;)
So far...I'ma thinkin'...maybe
...something like this :unsure:
After makin' the first one or side
...I used "it" as a template ta make another
After addin' some motor mounting "slots"
...& some trimmin' or "body work"
Double checked by Quality Control
...yup, they look ta be the same ;)
...but, opposite :p
Another view
* Yes, I will agree that the "slots" are NOT quite perfect :mad2:
...but, can & will attest that the fact that, they "will do" :thumbsup:
That material looks like 3/16 or maybe 1/4? How did ya bend that?
Hey T,
I'm tryin' ta keep 'er as light as possible
...but still be able to "handle" all of the different "stresses" that will be imposed on these Nacelles :2guns:
Like
...supporting the whole racer (w/driver) while traversing the racetrack
...& being able to "handle" all of the torquing/thrust forces, of accelerating
...plus, all of the anti-thrust/stopping forces, of braking
So, I'm tryin' something different
...the "plate" is made out of~10g. steel
...& the U-bracket(s) are made out of ~1/8" steel
I just bent 'em with a DIY/homemade bender
It's the same bender that I used to make the "legs" for my DIY/home made "Truck Rim Fire Pit" (~5 yrs. ago)
...& them "legs" are made outta 1 1/2" x 1/4" steel ;)
* The bender can be seen "in action" in the video :thumbsup:
What wheels are ya usin'?
I have a 6" steel rim with (4) studs (for a rotor or sprocket) left over
...from when I was "trying" different parts for my Tsunami racer
So, I got another one ta match 'er :thumbsup:
Had an issue...though :furious2:
The (4) studs on (1) of the rims had a lot of the power coating on them
...& I figured that "running" a nut down them a couple of times would "clear" it off
But,
The nut got stuck on (1) stud (with extra thick power coat)
...& when I went to "back it off" the stud "unseated itself" :(
Plan B
I rounded up a 3/8" fine threaded DIE
...to "chase" the threads (should have done this...in the beginning) :mad2:
...but, the handles, on the DIE holder, would not "clear" the other studs
So, I had ta get creative
...& "make a tool" ;)
A "slim" DIE holder
...with an adjustable/removable handle :sifone:
Inside view (w/power coat debris)
On a stud
Top view
Yup, that's better
Hey...why are them studs "stuck" into the workbench, in that pic with Ducky...the cat?
I drilled (4) holes (same spacing/pattern as on the rim) into the workbench top
...to use as an "aid" (another hand)
...to help secure the rim (hold 'er in place)
...ta mount the tire
First, I got tire started
Gotta make sure the "tucked in" side "goes" down into this "low area"
Once the tire is on/around/over the rim
...I "pulled upwards" on the tire to kinda "seat the "front" side
Then, "flipped" 'er over
...& "pulled upwards" on the tire
...while "holding" the rim down
...&/also, adding air to the tire
The tires are 15 x 6.00 x 6 Ribbed tread tires
...& they look like this...when done :thumbsup:
I
thought Ducky sat on the rim and drove the studs into the workbench. Is she preggers again? :roflol:
I
Oh...No...Oh HECK No :eek:
Ducky has had (2) litters
...&/so, she has provided us with (9) "new" family members
...& we LOVE them ALL :love:
...but, that's ENOUGH :ack2:
First litter: Henry, Almond, Boots, Rusty & Emmy
Second litter: Socks, Cashew, Creamora & Angel
Crazy thing,
Almond (from the first litter) is a mostly white cat
...with a tan "hat"
...& (almost) heart shaped spot on his back
Cashew (from the second litter) is also mostly white
...also, has a tan "hat"
...& a tan spot in his back, too :thumbsup:
Almond
Cashew (& Creamora)
This is Emmy (she looks & acts most like her mom...Ducky)
