Drift trike for the grandbrat!
So my 10 year old grand brat brings me his pedal power drift trike. He says granpa my bike is broken, can you fix it? So I puffeds up my chest and said "of course I can fix it! "
The bearings are falling apart from excessive use/abuse, among other problems.
So I did what every good granpa would do... Stripped it down and started planning a electric conversion.
Trying to figure out the gearing for this thing. 6:1 isn't gonna work cuz the wheels are only 10 inch diameter.
So someone confirm this please, I don't trust my thinkin lately.
10 inch wheel X 3.1416 = 31.1416 inches circumferance.
Motor speed (maximum) 3000RPM
3.5:1 Gear ratio = 857.14RPM (maximum axle speed) (3000/3.5)
31.14 in x 857 MAx RPM = 26,691inches/minute (max)
26,691 inch/min = / 12 = 2,224 Feet/minute x 60 = 133455 feet/hour
133455/5280 = 25.276 MPH
Sound right?
Math looks correct ( didn't run it out to check for accuracy ), so your thinking is probably better than you are giving yourself credit for. I think the real question is how much torque does the motor make. That is if they even list torque specifications on electric motors.
Thanks for the confirmation! You have no idea many times l went over this B4 l started to get comfortable with it!
No tork specs listed, but l'm guessing its big, and instant.
48V 1,000W Unite MY-1020 brushed motor specs:
Model: MY1020
Voltage: 48 Volt DC
Output: 1000 Watt
Rated speed:3000RPM
Rated current: 26.7A
Rated Torque: 3.2Nm
Weight 5.25Kg
1Kw power. Ungeared. Suitable for large scooters or bikes and trikes. You would use these in a setup where you wanted to retain the original gearing. Extremely powerful, one of the largest motors Unite makes in a brushed motor.
Sound right?
IMO a 3.5:1 GR it too high
FME 6:1 is about ideal
...but, 5:1 is faster :thumbsup:
This is how I have been doin' it ;)
Ballpark Equation
MS/GR=ASxTC=IM/FT=FMxHR=FHxMM= MPH
Motor Speed/Gear Ratio=Axle Speed x Tire Circumference = Inches per Minute traveled/Foot(12) = Feet per Minute traveled x Hour(60) = Feet per Hour traveled x MPH Multiplier(.000189) = Miles Per Hour
If the motor does ~3,000 RPM's
...& were running (for this example, let's say) a 5:1 gear ratio (10T drive sprocket, on the motor & a 50T driven sprocket, on the wheel)
...& (if) the ~10" wheels, have a ~31" cir.
Then, the math would look like:
3,000(RPM)/5(GR) = 500 (axle speed)
500(AS) x 31(TC) = 15,500 (inches per min-traveled)
15,500(IM)/12(FT) = 1,291 (feet per min-traveled)
1,291(FM) x 60(HR) = 77,500 (feet per hour-traveled)
77,500(FH) x .000189(MM) = 14.65 MPH
I need more top end. 14MPH ain't gonna get it. I'm thinkin somewhere around 25MPH would be mo bedder?
Well, here are the "numbers" if ya use a 5:1GR (10T drive & 50T driven)
...with the 10" (~31" cir. wheels) :cheers2:
Ballpark Equation
...& were running (for this example) a 5:1 gear ratio
...& the wheels have a ~31" cir.
3,000/5 = 600 (axle speed)
600 x 31 = 18,600 (inches per min traveled)
18,600/12 = 1,550 (feet per min traveled)
1,550 x 60 = 93,000 (feet per hour traveled)
93,000 x .000189 = 17.58 MPH
So, accordin' to the "numbers" a 5:1GR would/should produce ~17.5 MPH :thumbsup:
IMO almost 20MPH is pretty quick
...when your only ~3" off of the ground
...& a vehicle like that, doesn't provide much protection
How old is this grandbrat? :unsure:
Um...
These numbers would be for a 6:1GR
...NOT a 5:1GR
MY BAD :confused:
So, to be clear(er)
...in this scenario
A 6:1 GR = ~14.5 MPH top speed
...with pretty quick acceleration
A 5:1GR = ~17.5MPH top speed
...decent acceleration
A 3:1GR = ~29 MPH top speed
...but, would have very slow acceleration
I could'nt grasp the manual transmission on my older sisters Ford Escort when I was 14. I bought a Yamaha Special 50cc when I was 15 with a 5 speed trans and picked it up right away and figured out the "manual trans". Hoped into my sisters Escort again and drove like champ.
And yes, faster and fearless means he's on the right path!!:cool:
Looking at my calcs above l agree 3.5:1 is too tall. I doubt that would even work at all.
This contraption probably be around 250# or less with the rider, so we'll start @ 5:1.
With that ratio, l'll need to see everybodys friend Jack Shaft. A 50 tooth sprocket on the axle wont leave much ground clearance.
He has grandpa yelling "NEVER LIFT" at him whenever he drives the "pile-o-scrap"
So, new plan...
Using a jackshaft, and 10/30 (motor to JS) then 18/30 (JS to axe)
using my abacus it comes out at 5:1 Please check my calcs.
l have officialy renamed the blue mobile scrap heap. Fromthis date forward it will be known as the "pile-o-scrap".
Hey T,
Incorporating a Jack Shaft adds weight, friction/resistance & performance reduction/losses
...'cause of the more chain, bearings & gears
Remember, that little 48V 1,000W motor, has a ~1.2HP rating
...whereas your common ICE (internal combustion engine) like a Predator 212 has a ~6.5HP rating
&/so,
The losses of a JS wouldn't be noticed as much
...on a kart with a 6.5HP engine
...as they would be on kart with a 1.2HP motor :cheers2:
Q:
Where do ya plan on mounting the sprocket? :popcorn:
If the sprocket is really close to the wheel/tire
...it has much less chance of hitting the ground
...&/or "bottoming out" :thumbsup:
Maybe something like on my Torsk (backbone chassis) kart :auto:
