Echodeified
- Messages
- 4
- Reaction score
- 7
Hey everyone,
This is my first build: a homemade mini chopper trike built completely from scratch using repurposed parts and raw creativity. Frame is all custom steel tubing, bent and welded by hand. Engine is a 212 Predator, mounted to a reinforced base plate with custom chain drive to a dual rear axle setup. Tires in back are ATV-grade for extra grip, front is a classic BMX rim with a wide fork for clearance.
Forks were handmade using stainless tubing and bolted through double-bearing headset mounts. The stem tube is reinforced with double gussets and a tensioned top clamp using a beefy bolt stack. Steering is smooth and stable with minimal wobble.
The green seat? Believe it or not, it was originally the top bracket from a wooden swing set. I cut, reshaped, and welded a pivot bracket underneath, and added coil springs for suspension. Springs rest on a metal plate that was once part of a 6" check valve flap—welded to a vertical gusset cut from a trailer hitch frame. Rides like a dream.
Still tweaking the ergonomics and throttle cable routing, but she’s running strong and ready to rip.
Any tips on improving front-end stability or seat angle welcome. Appreciate the feedback from you OG builders.
Pics attached. Let me know what you think!
