Again with my wiring problems..
johntheboxer
NorCal
The transformation of my electric Mobility scooter to a Fossil fuel forestroke is coming along quite nicely except for...? yes my wiring problems again. Actually the wiring isn't doing anything wrong It's the owner-operator. Please check out my photos before opinions on my or not wiring abilities. Soooo I only have 5. FIVE! wires coming out of the motor. What do those 5 wires attach to? remembering that i already have hard wired CDI box. Everything is set up attached to the build and ready to go I just don't know where to stick the wires. (Figured I would make at least, one loaded statement)
I value everyone's opinion and sense of humor.
johntheboxer
NorCal
Do not use the yella wires! It will explode!
But Holy crap Batman, how will I charge my battery and power my headlamp? Upon turning the motor over I have found the blackwire supplies a sufficient amount of AC power. 😖⚡️
Thepartsguy
That’s just two wires off the trigger and 3 wires for a 3 phase regulator off the engine probably zero difference to a gy6…
Just about any cdi can be wired into about anything and it is very easy to do. If you re-check this post I can help you wire it in.
Cdi performance is even making them for the 212 predator with screwdriver adjustable timing off the box launch control and a flame thrower button. Cdi’s are fun
Thepartsguy
I’ve talked about this before but once the trigger is made and the flywheel is timed without a key you can use a home made trigger and 6al for 2 step and other good stuff.
