Just serviced a fourwheeler doing the same thing today. Start it on ether and turn the choke mostly on. Then it would lurch and jump forward then shut off.
It took 10 minutes of BS’ing with him and I got the carb off. A bunch of junk in the passage between the needle and seat and fuel inlet.
Some compressed air another 10 minutes to re-assemble.. Easy $50
The lung test with no needle in the seat it was like they didn’t drill the seat big enough.. only a very small amount of air going through the seat. (Until) the dirt blew out and i could blow air through it enough to KNOW fuel would flow through fine.
Yeah after I posted I pulled the bowl plug with the fuel off to empty it, and cut the fuel back on, flow is fine there too.
I'm suspecting a situation the pilot is a bit small but the Main is too big... which shouldn't be a major issue because it was running great before it decided it was done.
It was passed to me to look at because it did this before and was fine again after a week sitting, but it was noted it had significantly less power.
I do know there's A key issue on the axle, drive gear is 90° off key, which is easily the power loss but the not running bit can't be related.
I've ruled out all major mechanical so the only thing to do is poke at the carb more, and maybe tell dude to replace it... has a mixture circuit that can't be adjusted anyway
