Propane that's the question.
hardcorewill
Sc
Does anybody have experience with converting a dirty burning gasoline engine, to a much more natural and more environmentally friendly source of propane. Your friend Hank Hill.
hardcorewill
Sc
Propane is 80% is efficient as gasoline so that means you just burn more? Correct?
I've thought about it. Unless you get an engine that's already set up for Propane, conversion kits are a pain to find. To help alleviate some possible power loss, with propane having around on average 110 octane, so you can run a higher compression ratio.
Them cans of propane are a hassle. Fuel consumption is up. I didn't like the overall PITA, but the engine ran nice. The problem of flooding goes away in real rough, off camber terrain, heck it can run upside down.
Also no need to change jetting for elevation changes, just the initial change for it. However it can cause carb bowls to stick because there no gas to help keep it semi lubricated.
There are advantages like keeps the oil cleaner therefore the engine too. Less wear from particulate matter. But one down side is you just can’t pull off a trail and gas up. Not everywhere carries propane. Plus knowing how much is left in the tank exactly can be problematic.
The only accurate fuel gauge is a scale.
unless ya have a scource close by, refueling is a problem, not very convenient.
Sure full size vehicle with a forklift propane bottle works (they are DOT approved). The gauges for those are hit or miss, but if a dual fuel engine is a possibility, you can run it on either gas or LP gas and switch over if one is low.
But you will never get it all back. I played with a 13:1 350 Chevy not worth it. However using it on a diesel as a power adder seems to up the power quite a bit. Like 15% more power!
