Darren
I been reading up on a few other old 4cycle posts, and you can draw the timing marks through the on off switch, so you can happily run the kart, then switch it off by earthing out the switch on the crankcase somewhere. Timing lights can only show actual ignition timing, for instance, it will show you if you've put the offset key the wrong way round. The timing light will also show if the timing is falling behind and if the coil has a limiter as part of the circuit, although it won't confirm if the cap is a rev limiter.
There's a guy who showed how to bore out a gx carb to give better flow characteristics. It looks like he's done a few, might be worth playing around with, Just need a reamer and jet kit, he only removes a small amount of metal, guess less is more.
I've never done it, I'm usually at stage 4/5 on an engine build, not sure what stage a full efi system would fall into
