Homemade diesel project...
thatkartbuilder
Perry, OH
Here's a few pictures
thatkartbuilder
Perry, OH
I had to take the shocks out of the front and replace them with bars, this steered a lot better. It used to not be able to steer with the shocks in forward, but in reverse was good, now without the shocks, the steering in forward works perfectly, but I am trying to make it steer with shocks.
thatkartbuilder
Perry, OH
I do plan on making a roll cage today, bought a little 110v flux-core welder... for $70 its awesome, I'm a good welder, heres a good sketch of the roll cage idea:
It won’t roll with those tires you drew. It will be very bumpy. Also that pointy seat may spear you. But the rest of the kart looks pretty good! Did you build in Ackerman angle? Use a steering rack? What kind of problems are you having?
Now about your cage design. Remember triangles are the strongest geometric shape, so lots of triangles in the cage design. No members that lead to nowhere!
thatkartbuilder
Perry, OH
Yes, when I was to drive forward the kart's tires would fold in, or wouldn't steer right, I am using a steering rack and doing reverse Ackerman.
I am unsure why this idea of rack and suspension doesn't work for each other. I may have to replace the rack with regular tierods an it may work better. All of my suspension components are homemade, so they aren't perfect or have ball joints, which gives it slack.
thatkartbuilder
Perry, OH
Isn't finished yet, but is close to being one
thatkartbuilder
Perry, OH
I have so many things to install on this build, a key switch, electric start, battery, lights, spare tank, electric fuel shut off, possibly an alternator, and turbo... yes I have both of these, turbo being a little big tho and would just be for looks.
(Edit: I do have all of these things, they just need to be installed)
What is the HP/TQ rating on that Diesel?
You can’t fool us, that is not a “ homemade Yanmar diesel” as claimed!
Thats a real yanmar diesel!
I like everthing diesel. I have a diesel lanwmower, truck, generator etc. Now l’m looking for a diesel toaster!
Good luck! Looks great!
Snaker
Front suspension: Have to shown a series of photo's
Rear suspension: That is some long extensions on the shock mounts.
Lots of forces there.
Might need to beef up that area.
I had a Yanmar 2 cyl.
It was older and it was also a wide open air intake design.
Those things are subject to runaways
I could see engine oil getting splashed around with that rig.
If yours doesn't have some version of air throttle, I would incorporate a emergency butterfly close-off for it.
Snaker
The only ones that used to run away were the Detroits with the Roosa injection pumps.
I guess you missed the bus again.
I had a Yanmar with a wide open air intake.
As in, there was no throttle control of the air intake.
As in, the throttle controlled the fuel injection only
Stay in school and say no to drugs there, chief.
thatkartbuilder
Perry, OH
I have some pictures of the front suspension... I'll get some better ones later today:
Snaker
Your tie rods are somewhat longer than your suspension arms so you will get some bump steer.
But it doesn't look crazy out of proportions.
Is everything tight with no slop?
Any toe in or toe out?
