Nimdy
I recently bought a new Predator 212 non-hemi that I am building out to run on methanol, I have installed an ARC 6252 billet rod and a DJ-1285PH flat-top piston with it. I also installed an ARC 6695 billet flywheel, gave the head a port job, installed 18lb valve springs with 1.3:1 ratio rockers, and installed a 0.010 head gasket. what I want to know now is the volume of the head so that I can calculate the compression ratio for documentation purposes (I'm doing this for a senior project so I need to write this kind of stuff down). Still, no matter how much I search online I can't find any info on the volume of a non-hemi head. I have seen posts saying the hemi head has a volume of 22cc but I'm not sure if it's the same for the non-hemi. any information on this would help a lot.
