I've been chasing a vibration problem, that I have isolated to the rear tires/wheels. After finding out none of the local tire shops are willing to balance ATV tires I needed to come up with a hack solution, to reduce the vibration. So after a few hours of 2 am engineering I came up with a solution that actually works somewhat.
The first thing is to figure out a way to locate where the imbalance is on each offending wheel.
I made a flange to put the tire on and then located a point on which to balance the assembly.
While it may not appear so it is imperative that the point be straight, a level accomplished that task.
The tire/wheel was then placed on the point and...
So, then I gave the assembly several opportunities to find where it wanted to hang. When I was satisfied that I had the right spot,I set some weights opposite the heavy spot and...
So the whole process took only an hour or so, and while far from perfect, the bottom line is, the vibration is greatly reduced. and that is what I was after!
