Yes, you may be able to bolt it to the predator and change the gear reductionthe case of the reduction box?
how i change the gear reduction? like with the sprockets?Yes, you may be able to bolt it to the predator and change the gear reduction
There is either gears or sprockets inside that reduction box and you might be able to change it. Split the case and take some pictures of the inside of the box.how i change the gear reduction? like with the sprockets?
You could most likely bolt this setup to your 212 ghost engine. You could also probably change #16, the sprocket, to somthing smaller to get more top end.i opened like 4-5 months ago but practically that all the components that are inside
thats what im trying to find and thats why im here so you guys that know this things better than me could help me out to find the correct parts for these upgradeYou can not bolt this gear reduction box to any predator!!!!!!! Crankshaft is wrong diameter and length. Smart money is to sell this kart to someone who will use it as is and build something new to your liking. The kart will never work with the ghost unless you have a few jackshafts to change gear ratio.
