Easy valve core removal tool
If you lost your valve core removal tool or you don’t have one, here’s a super easy homemade solution.
Grab that useless multi size flathead screwdriver bit set and find one that fits your housing. Bigger is better here. IMG_3241.jpegIMG_3242.jpeg
Cut a slot using any means necessary. I used a Dremel cutting disk.IMG_3243.jpeg
Throw it in the screw driver and use it. Keep it with the set so it’s not lost as easily.image.jpg
You just used your inner @Master Hack, congratulations!
BrownStainRacing
Grab that useless multi size flathead screwdriver bit set and find one that fits your housing. Bigger is better here. View attachment 138976View attachment 138977
Cut a slot using any means necessary. I used a Dremel cutting disk.View attachment 138978
Throw it in the screw driver and use it. Keep it with the set so it’s not lost as easily.View attachment 138979
Awesome!!!!
You jus saved somebody time, money and aggravation!!!
Thats what "diy" is.
Good job!! 👍
