BrownStainRacing
- Messages
- 1,367
- Reaction score
- 1,486
@LtDansNewLegs
Before you put your order in, check crank end play. I set em at .010". Every pred I've seen, needed the crank shimmed. It keeps the crank from beating the sides of the rod, and every things stays nice and straight.
Little things like this helps the upper rpm range.
I shim the cam too, but you gotta pull the crank and use hole in side cover to measure cam end play.
Crank shim kits are usally 4-$5.
