Manco Interceptor Refurb.
dustin.s
KCMO
Manco Interceptor, model 104D-07
My son’s first kart. The goal is strip it down, eliminate reduction chain drive, replace with CVT converter mated to predator 212cc, replace bearings, brakes, and tires. The seat bottom is rotted out but the seat back and all the vinyl is in decent shape for its age. Sand and paint rusted areas on kart and wheels. Then, SEND IT!
dustin.s
KCMO
It is just begging for big @$$ tires
It is! The axle/frame setup doesn’t allow for much without having some serious front bias lean. Also, the stock axle is only ~28”, not allowing for much in the width department. We’ll see how much my son enjoys the hobby. If it’s in his blood I’ll swap to a 3/4” x 35 1/2” axle to allow wheel and tire upgrades.
G.W
Nyssa Oregon
I'd beef it up to a 1 inch axle. Boy is that 212 crammed into that frame, that thing is going to be fast
dustin.s
KCMO
If I ever decide a 1” axle is necessary, I’ll put it on a 1 1/2” tube frame. No real gain upgrading to 1” except in the amount of wheel/tire combinations. The frame, I haven’t measured, but would guess is probably 3/4” tube. For now the 5/8” axle, albeit an odd size, will suffice. I know I can upgrade to a 3/4” axle with little effort with the availability of bearings that are the same nominal OD (1 3/8”).
As for the engine, it fits well, but has a larger displacement(212cc) than the kart originally(126cc) intended. The only hiccup I can see is the alignment of the driven gear on the CVT and the axle gear. Looking forward to using a few choice words in the future.
I feel for you on gear alignment. I'm locked out of a TC with the whole setup on my kart, without some cutting welding and an adjustable engine plate.
G.W
Nyssa Oregon
The only way I can cut the jackshaft from my build is welding in a whole new engine plate. No big deal since I'm upgrading to a 459cc max predator engine.
dustin.s
KCMO
Just curious, do you have a picture of the output side?
dustin.s
KCMO
I little work on the kart tonight. I mounted the CVT and scrapped some the loose paint. Cleaned up the vinyl on the seat and side pads. The good news is that the mock up with the CVT appears as though the driven gear and axle gear align perfectly with no modifications. I measured the frame tubing and to my surprise is 1”. More stout than originally thought.
G.W
Nyssa Oregon
Thanks for the confident tip.
I cleaned only the surface rust, and here is what it did to the deeper rust on my ct90 frame. I meaning when I say it works great. That was bare metal with rust on it, it turns black
G.W
Nyssa Oregon
All the black speckles is where there was rust starting to get deeper into the metal
dustin.s
KCMO
Getting things sanded and primed. I did have a question for those familiar with the predator 212 line of engines. The model I have is 69730, which is not supposed to be a “hemi”, hemispherical piston. However, the valve cover is cast material and rectangular, which is typical of a “hemi” engine.
G.W
Nyssa Oregon
The model number specified it’s not, but I’m thinking like you, that’s a hemi valve cover. I’m going to have to pull the head at some point to verify.
No need, the he.i and non hemi valves are a different shape, and don't interchange. Another thing is the hemi cover is cast and the non hemi is pressed sheet metal. It is without a doubt a hemi
Somewhere within the last month or so l read that Harbor Freight had changed the numbers, so that all of the 212cc engines had the same product or model number, regardless of if it were a hemi or not. No need to pull or remove anything. G.W is telling you correctly, your engine is a hemi. You need to know that only if you go to install aftermarket hop up parts. Aside from carburetor and header pipe, practically nothing is interchangeable between the two engines. Yours has the better piston, as it is a flattop. Non hemi's come with a dished piston. Combustion chamber is a little smaller.
BrownStainRacing
This guy's explains some info about the boxing. Looks like they using what ever boxes and stickers with model #'s on whatever they like.
Theres a lil more difference in them then jus the head. The blocks are different, so they take a different cam. The cranks are different, so they take a different flywheel.
But yes, that is a hemi HEAD
