GX360K1 carburetor upgrades.
Lfunder111
I'm new to these forums, so if I didn't do something right please let me know. I have a GX360 K1 that I plan to eventually put into a go kart. I've been working on the motor and trying to mod it the usual route, better flow through head, less restrictive exhaust, heavier valve springs, ported head. My only real roadblock so far is the difficulty in finding what size mikuni carb I need. I'm trying to get away from the stock carburetor as I prefer the motorcycle type slide carbs, and I really don't like the butterfly carbs. I've modded single cylinder engines just fine, this is the first 2 cylinder I've worked on and I'm not entirely sure how carburetion compares to a single cylinder.
BSR#2
Welcome!!!
That's an impressive engine you have there.
Do you think the cooling system parts will handle the extra rpm, the slide carb will be allowing????
Staff Murderator
...My only real roadblock so far is the difficulty in finding what size mikuni carb I need.
Pretty certain the first of your concerns is if the Mikuni you choose has the same bore diameter as your intake manifold, but you are in uncharted territory running with that little beasty.
I'd say look for comparable builds using the same motor or an equivalent sized motorcycle engine, any brand, and look at what it uses for carburetion. Then go from there. You may end up experimenting with several different carbs of varying sizes. . . .
