First time carting….
Ricky77
Hey guys I’m Ricky from Fischer,TX live and work on a ranch living out of my RV, I have boys 8 & 10 yrs old I’ll have them for majority of the summer, that’s the only reason for the cart…lol.
So I got picked up a cart, unsure of model and have no clue on how to get it back together. I do have solid experience with ATV, dirtbike and UTV. Please help.
You’ll need an bb engine plate and a 40 series CVT system and enough parts for a jackshaft kit. GoKart Supply, BMI, Manufacturers Supply, Go Powersports and the jungle store are your new best friends.
electraglide
Rick ... looks like you have a Hammerhead judging by the logo in front. ( prob Mudhead 208R ) Several models look like that. see link ... https://hammerheadperformance.com/technical-info ........ I am in the same situation and I am learning as I go. I have a Trailmaster Mid XRX which is very similar to yours ... pretty much use the same parts. I suggest going thru the manuals and parts lists on the link, compare and find out which Kart you have. You will be able to tell what you do have and what parts you need. Then you have a better idea as to asking specific questions like where to get it, how to install it or connect it. Karrtekk member on this forum has a Hammerhead and is very helpful. You tube is also a great help installing the motor, upgrading to electric start, hooking up the wire harness ... etc.... lotsa help. ...... https://www.bing.com/videos/search?q=hammerhead+mudhead+208r&FORM=HDRSC4 ........ I live an hour away .. go to Canyon Lake a lot. ... welcome to the club ...
electraglide
look for the VIN number ... makes a difference on parts list ... looks like yours is setup with reverse. Something you have to decide whether you want to fully restore it or go bare bones , no fiddling around with dashboard connections , reverse parts, no electric start ......
Ricky77
That’s extremely helpful! I will check the links and thank you!
Ricky77
I’ve been watching…a lot of videos. I posted a pick of the backend, do I need a new axle? I can’t even fit this 301 in here unless I chop it up. Just needed some reassurance.
electraglide
If you have the time, money, knowledge and the means go for it ( gut feeling ) if your are missing one of those you might spend most of the summer fixing a problem that may lead to to other problems or mods. You may need a different axle if the problem is width wise ( may cause and lead to other mods, otherwise go with what Denny suggested.
Ricky77
When I get my torque converter in I’ll see how much space I’ll have then weld a plate of course for the engine still. It seems to fit?IMG_1973.jpegIMG_1968.jpeg
BrownStainRacing
When I get my torque converter in I’ll see how much space I’ll have then weld a plate of course for the engine still. It seems to fit?View attachment 138177View attachment 138178
With the engine sitting that way, you will have a very good... REVERSE ONLY, buggy.
Pull the rope and see the direction of the crankshaft.
You need to turn the engine around, build a engine plate that will support a 40 series t/c and jackshaft that will be long enough to reach over and line a small sprocket up with the axle sprocket.
You can flip the axle, but then you have to move the brake caliper bracket.
Ricky77
And that’s why I’m in here…thank you
BrownStainRacing
You can get more of an idea of what you will need, if you take off the gas tank, muffler and airbox. Jus keep the exhaust port and carb opening covered or plugged. This will give you more clearance between top of engine and bottom of the rack. This makes it lighter to move around, also.
You can alway mount a tank to the top of rack, like the buggy tank, install an aftermarket header and airfilter later, if need be.
The engine will need to be raised up so the driven pulley will clear the axle.
I don't know of any c or b type jackshaft sprockets that will fit that chain. So there's a very good chance you will need to change the axle sprocket to match the jackshaft sprocket.
The engine/ jackshaft plate will need 2 pivot points on the front, so the back of the plate can be raised or lowered to tighten the chain from the jackshaft sprocket to the axle sprocket.
I can get pics from my grandsons buggy, if it's confusing.
Ricky77
Please! This is great info! Pics will only help! Thank you
BrownStainRacing
Here ya go.
You would need a much wider platform for the jackshaft to reach over to the axle sprocket.
I got some aluminum plates to raise engine so driven doesn't hit brake disc.
With some square tubing, gussets for brackets, and 1, maybe 2 adjustable bolts with nuts should get you there. Looks like a simple diy job to me. Lmk, if you need more pics.
