420 predator wont fire. After replacing electric starter.
Robr0924
Was running but starter was going bad. Replaced starter, and now it won't fire. I have tried starter fluid and gas, won't fire at all. I have spark, compression. I thought it was bad fuel, drained tank and put in fresh gas. Fuel is pumping from tank to carb. I switched out carbs, as I had a new in box car. From when I bought the Cart. Still nothing, I'm guessing timing, but I haven't touched that and can't figure this one out. ANY suggestions appreciated.
Robr0924
Thanks for the reply, I got it running. I replaced the original card and setup alternative fuel source. Shot starter fluid, while turning it over and it fired. It likes to be choked alittle to get good range up and down. Drove for 30 minutes idles and starts up quickly. Assuming it was fuel starved. It is setup how it was when I brought it.
Robr0924
Are you sure you hooked the starter up correctly?
