yk31c not working please help
Leo231
so i have a yk31c controller (36v 500w but im using 24v).
when i got it i wired all the important stuff for a bench test (motor wire, power, lock, throttle)
and nothing happend. I tried everything to make it work but i cant figure it out so im asking for help!
Howdy & :welcome2:
"I have a 36V controller but, I'm using 24V"
IMO there's your problem
...so, you'll need another 12V battery, to use that controller
The Low-Voltage cut-off of most 36V controllers is ~31.5V
...this "safety" feature will shut down the power (to the motor)
...so, you can't over-discharge (& potentially damage) your battery pack
But, "if" your only using a 24V battery pack, the top charge voltage (of that pack) is probably only ~27V
...which is not enough voltage to power a 36V controller/system
Here is a listing for a 36V YK31 speed controller
* Notice the "Short Voltage" (AKA Low-Voltage Cut-Off) of 31.5V, on the label? ;)
https://www.ebay.com/itm/1542596113...ce7VzW1FbFvpQppQQXUkqGtHYA==|tkp:BFBM1Oj8svZh
Also, here is a video I made a few years ago
It's for a 24V system
...& all of the concepts are the same
...except for the Voltage requirements of the battery pack
* Notice the "Short Voltage" (in Chinese) of ~20.5V, on the 24V speed controllers label?
Leo231
i tested it and it worked! thanks!
though i dont have a 36v motor so is there some way to bypass the cutoff?
edit: i found how to do it (i can change R31 from 3.6K to 4.7K)
Kool & your welcome! :thumbsup:
No, not really as it's an integrated safety feature
Well, (2 options) your gonna have to either get a 24V speed controller, to work with your 24V motor
...or get a 36V motor to work with your 36V speed controller :cheers2:
I'd go bigger
...but, it really depends on what you're working on
...kids kart?
...adult kart?
...other?
Leo231
took it for a test drive and found a new problem...
it stutters when under load, and i think the reason is some other resistors are connected to the one i changed.
and when i change one the others might get offset too.
heres a schematic (i changed R31)
