Cheap Mods to Boost 3.5hp Briggs
CoyCaller
New to go karting
Broken Bow, NE
I put together a 2 seater go kart for my kids. The engine runs well but is a little short on hp. To be expected I suppose.
The motor has to really grunt to get the cart rolling and I am worried that the clutch will burn up quickly with all of the slipping that it must do to get the Kart going. By modifying the kart I hope to eliminate some of the slip time thus saving the clutch. I am not as worried about having a hotrod as I am about damage to the clutch.
I guess what I would like to know is, can I add some torque to this little guy without too much expense? I have tools and know how to use them but I lack in knowledge on the places these tools need to be applied to the Briggs engines.
Thanks
freakboy
the names 'mater
hick town
If you make a intake manifold that extends the carburetor away from the block that increases toruqe. And if you want to im not sure if it could hurt your kids ears if you make a header for it. just a strait pipe about 12 inches long. those should help performance a little bit.
CoyCaller
New to go karting
Broken Bow, NE
I could extend the manifold easily enough. Two drilled plates and a pipe welded between.
How long should the extension be?
Does porting the intake help the low end?
EagleTalons
Master JB Welder
Forsyth, Montana
Ya know, I'd only do the free mods, because if you spend money on that low of hp engine, its just not gonna make enough to ever make you happy. Find a Briggs I/C 5hp. They have cast iron bores and can make much more power than 5hp with a few simple mods. Cheap mods too at that!
CoyCaller
New to go karting
Broken Bow, NE
I'm only going to do the free mods and see what happens. It will make me happy if it makes the kids happy. (It just has to move to accomplish that.) More than anything I just need an excuse to tinker in the shop.LOL
I am looking for a five horse briggs to begin working on for the next go kart.
I have a few friends that race karts. They are running clones now but were telling me about their Briggs engines. They said something about drilling out the jets in the carb, any info on that?
freakboy
the names 'mater
hick town
Only if its well moded and needs more fuel. since this is a kids gokart dont even think about removing the gov.
If your kids are doing a lot of low speed, stop and go type driving you might just need to install a larger rear sprocket. You'd loose top speed but gain torque and acceleration. Your curent engine and clutch would get it rolling much easier.
We could help you figure out how your kart is geared now if you post the # of teeth your clutch and rear sprocket has, and then also the height of your rear tires.
CoyCaller
New to go karting
Broken Bow, NE
12 on the clutch
72 on the drive wheel
Tires are 14 inches tall
t0x1k
Vroom
South, NJ
12 on the clutch
Those tires are pretty big for just a clutch and 3.5hp imo.
Stick a jackshaft on it to gear down more, you'll lose a bit of top speed, but it'll be like putting a bigger sprocket on.
Or just use smaller tires.
Assuming your engine is still governed and turns 3600 rpm, you should be topping out at 25mph now.
Here's a gearing calculator: http://www.diygokarts.com/speed-calculator.html
Actually you've got it geared prety well already but someone might sell an even larger drive wheel sprocket to fit your application.
As long as the frame (or anything else) isn't in the way, you can usualy get away with running a sprocket nearly as big around as your rear tires. (I run a 73 tooth with my 11.5" tall rear tires)
