Thepartsguy
- Messages
- 1,552
- Reaction score
- 1,439
???????? Not understanding. Does the diff have to take the full torque of the motor or not? Does it not have 2 separate pieces of axle sticking out of it on either side? Doesn't the full weight of the rearend (with riders aboard too) bear down vertically (at rest) on those bushings?It’s a differential, an open rearend! The gears and bushings mean almost nothing unless a wheel is spinning.
Had to look at a pic of my current kart to shake the cobwebs loose, brain was stuck. Full weight of rearend rests on the outside axle bearings.
The sprockets have a specific bolt pattern regular kart sprockets will not work. This is a 3/4 bearing axle. Keep in mind it’s just pipe over the 3/4 axle. the id of the pipe allows 3/4 gokart bearings to slip right in and the pipes can be cut to any length. I’m sure with the 1” axle you could source your own pipe and bearings to have it all set up like the 3/4 deal is. i’m almost sure you put 150ft pounds through one of these it’s not gonna hold. Wouldn’t bet on that but wouldn’t be surprised at all.Had to look at a pic of my current kart to shake the cobwebs loose, brain was stuck. Full weight of rearend rests on the outside axle bearings.
Zzzzzzzzzduhhhhhh.
I would say though that an extra pair of bearings sandwiching the diff is still a good idea. My kart has 4 pillow block 1" bearings with nothing but a sprocket and a brake disc on the 1-piece axle. Running each of the 2 half-axles through 2 fixed bearings each for a rigid axle setup would absolutely guarantee against uneven strain being put on the diff. Agreed?
Thanks a lot. Now it's stuck in my head. How much torque am I getting out of my 15+hp. Predator hemi 212 that came out of the box at 6.5hp. with 8.1 ft./pounds of torque. Now I'm going to create a migraine for myself trying to math out what the torque is now.150ft pounds
Not sure if kenbar sourced there axles for the streaker gokarts from peerless but I got two streakers and The diffs were sent to the scrapyard. they were powered by 5hp Briggs engines. I was saying this Diff wouldn’t be my first choice for anything past a Shriners kart on flat ground maybe ridden twice or three times a month. Your predator would destroy it. Quickly.Thanks a lot. Now it's stuck in my head. How much torque am I getting out of my 15+hp. Predator hemi 212 that came out of the box at 6.5hp. with 8.1 ft./pounds of torque. Now I'm going to create a migraine for myself trying to math out what the torque is now.
Think it's more than that 150 ft./pounds?
