Wanted: Briggs 5hp Flathead Cam
cml1of4
Looking for a mild cam for a briggs 5hp flathead. It's going on a minibike and will not be raced. Would just like to make a bit more power and have some more top end. I already have the flywheel, rods, and valve springs. Not having much luck finding them online. Looking to spend up to $100. DFW, TX.
karl
North east Ohio
All the spare cams I have require lifter bore reinforcement, definitely not mild.
But dyno cams have plenty of options starting at $60, all you have to
do is sent them a servicable core and they can help you out for
under your $100 budget.
cml1of4
I have a good core you can have for free if needed.
Yeah. That'd be great so I can still ride while I send the cam off. I can pay shipping. Do you have the part number on it so I can double check it'll fit my engine?
jmaack
I actually have 2. one was from a 74 the other a 95. I have no clue which is which. one has 43 and the other has 45 cast between the lobes.
Take your pick.
That is gummy oil not rust.
jmaack
Id take both if that was ok. I have a ton of briggs 5hp so they will get used. What about $20 plus shipping?
You can have them. Just cover shipping. Nothing else needed. PM me your address and I'll get you a quote. Or just use a flat rate box and put then in.
