I'd appreciate any info and specs... the most I can come up with is it was originally attached to a water pump of some kind (warning decal on the side of the shroud) and after measuring the bore and stroke its a 198cc.
I've cleaned it up and out. Fuel tank is a total loss because it was half full of water but after cleaning the rust out it was Swiss cheese... so full of pinholes and soft on the bottom.
I gutted all the Gov'nor crap, plugged the case, and cleared the ports of their atrocious casting flaws (nearly doubled the valve pot sizes by just smoothing and removing ridges) this thing should really scream when I get it back to the kart I peeled it off of.
I do not know:
The output power rating
Age (if the method is true its a 1987)
I DO KNOW that nearly all it's parts are still very available but also very expensive.
MODEL TYPE CODE
132232 0324-01 87051107
I do not know:
MODEL TYPE CODE
