Does/had they actually made their own?
The snowblowers I had used pulley's right off the engine, no engine mounted gearbox
Is that the case here?
It just doesn't seem when it's on full throttle to be full throttle. I'm going to throw a different motor on the cart tonight. When it's on the stand it just doesn't have any speed or power. It sounds weak and not at full.^^^^^^^^^^^^^^^^^^
Anyway they do the same thing as a predator , honda, or comparable motor.
Ive used the 179cc, 208cc, 208 stroked to 212cc, 357cc, and 420cc MTD snowblower engines with great success.
So I would lean towards a running or gear ratio issue.
What did you do for an exhaust and air cleaner? Is the throttle cable hooked to the hand control lever?
Does it move all the way right, full throttle, until it hits the limit stop screw?
Okay you answer the problem i put a 1 inch clutch on and it's a 7/8 shaft. Duh so is it possible to get clutches or chart converters for the 7/8 drive?Yes, after tecumseh stopped being competitive and went out of buisness, MTD had a big problem,
no engines for their snowblowers. So they made their own line of honda clone engines manufactured in china ,
probably in the same factory as harbor freight motors.
No reduction or cam reverse drive, but alot of the crankshafts are 7/8in diameter.
They even started putting 547cc singles and 670cc twins on their lawnmowers up until last year,
due to increased tariffs on china engines switched back to kohler and briggs. The snow engines are here to stay tho.
