Differential on Murray Explorer
drichards
My son and I got an old Murray Explorer (I think) that we are restoring. The axle has a differential on it (see photo). The biggest issue has been removing the brake disks so we can seat a new brake caliper. The disks are basically fused onto the axle. So my thought was to remove the axle. My question is, if we just replace the entire axle with a live axle, are we losing anything performance-wise by ditching the differential? Thank you!
Also, if you have any thoughts on how to remove the brake disk other than beating the snot out of it, I'm all ears!
Yes, you are loosing the corner turning ability. But only slightly. The way to remove the frozen on brake discs would be a penetrating oil and heat. Clean all the rust off the axle and disc with a wire brush and sandpaper. Then soak with penetrating oil, PB Blaster, Kroil, Diesel fuel, atf & acetone. Let soak for as long as need be and wail on with a hammer as necessary. Or you can add heat with a acetylene or propane torch.
drichards
Thank you so much! Very helpful advice.
I don't get it. Brake disc on top left is just sitting floppy on the axle with no hubs. Are you talking about a brake disc hub on the left side (out of picture) that's frozen onto the axle? If so, the wheel hub must come off first, does it come off easily?
Then there's the brake disc on the right side, what's going on with that one? Or is this a '70's flashback? The colors, the colors...............
drichards
Ha! Yea sorry it's a confusing photo. I can get that side off easily, but the other side can't move. I think I'm to the point of just cutting the axle off and ordering a new one and just going with a standard live axle without the differential. The axle lock collars are completely frozen.
AutoXdriver
Central North Carolina
Regarding live axle vs using the diff, I expect it is an "open" diff that will allow each wheel to turn at different speeds which is ideal for pavement use. If it's going to be run primarily in the yard, etc. then a live axle is fine, and even desirable if you want to drift/powerslide it on dirt/gravel, etc. because the difference in wheel speeds means it is breaking traction slightly in a corner already and doesn't take as much to "break it loose". An open diff will only spin one wheel under power.
