1970's Charger Kart (Stage 3 420)
@gokartgod
Thought you guys might enjoy these! Check out more of this project on Instagram @GoKartGod
Let me know what you think!
It was just meant to be simple project...
Here is the stage 3 Predator 420!
Straight Header
Mikuni 34mm Flatslide
Mod2 Cam
Billet Flywheel with Timing Adjustment
4.41 Billet Rod
Chromoly Push Rods
Stainless Valves (stock size)
65lb Dual Springs
AR390X Plug
5 Gallon Gas Tank Flush Mounted for the body panels
@gokartgod
Since the last photos, we ended up
- overhaul the pedal system (now adjustable up to 8 in)
- added MCP hydraulic brakes
- 10" Brake rotor which we will probably ditch
- re-worked the steering for a higher angle
- Added the body panels front grill and window
We still need to add
- GPS Speedometer
- Fuel Gauge
- Switch Panel
- Front and Rear Lights
- Head Unit and 4 in Speakers
- Alternator
- Wide Body Kit
- Spoiler
- Rear Exit Dual Exhaust
Also thinking about doing a Rotax 670 swap! Good or Bad Idea?
Kartin’ kid
None of your business (Aptos CA.)
- GPS Speedometer
- Fuel Gauge
- Switch Panel
- Alternator
- Wide Body Kit
- Spoiler
Hi there, I know I’m a little late to the party😅. Epic build! I love those old chargers. I was wondering what kind of quick disconnect setup you’re using
I doubt he’ll be back. He was just looking for likes from the uninformed masses. Won’t get that here. If something is unsafe we will call it out. Or if something is done poorly. With all that said he probably used a quick release for a race car from Summit or Jegs.
Kartin’ kid
Ah well :rolleyes:. Thanks for the tip. I was just hoping to compare it to my own setup
kart_goes_brrr
- GPS Speedometer
- Fuel Gauge
- Switch Panel
- Alternator
- Wide Body Kit
- Spoiler
POV The police waiting for you to ride that in the streets:
