Gearing and tire size advice
Brandon1320
Georgia
I bought a rolling Yerf Dog 3205 chassis. It came with 20" tires on the rear. I bought a Predator 212, 10T centrifugal clutch off amazon (Link), and it had a 60T sprocket. I weigh 185 and it is super sluggish to get going, it does slightly better with my kids but still pretty slow. I have been reading around on here about trying to increase torque so it at least takes off a little faster, I think that would be more fun for my kids. They don't get it up to top speed, only I do when driving. What does everyone suggest? Would a 12T clutch and maybe putting some smaller tires be best? Tractor supply carries 16" in my area. We ride on dirt and gravel roads mostly. I'd like to be able to hit the gas and be able to get going quick around the turns and hills we have.
Also on a side note, if anyone can give me advice to get my chain to stop popping off. I have "spacers" (a couple washers and a nut that the bolts go through) on the chassis to lift the motor up to tighten the chain, having it just sit straight on the frame I don't have a happy medium with removing/adding links to get it right.
Thanks for any input.
The centrifugal clutch is no good for your set up. You will need to step up to a TAV2 cvt 30 series type setup. Amazon has them pretty cheap just don’t use the belt that comes with the kit. Get a more expensive genuine Comet brand belt, it will last longer. You will be able to keep your gear ratios the same. 10 tooth on the drive and 60 on the axle.
Brandon1320
Georgia
Any deeper input on why the clutch is no good? Would my ideas, smaller tires and different ratio not make any difference? I have literally zero knowledge about these other than what I have done already. What benefit does the cvt offer?
C= constantly
V= variable
T= transmission
It’s kind of like having an automatic transmission in your Gokart. You start off in a lower gear ratio and as speed increases and rolling resistance decreases it shifts into a higher gear automatically. Which means you can keep your gear ratio and tires the same.
If you go to a smaller tire size you will loose ground clearance, axle sprocket clearance and chassis clearance. It will also mean you screw up your gear ratios and possibly have to add a jackshaft and more sprockets to compensate. Go to the Gokart Supply website it can explain it all to you and has tire size and ratio calculators.
pRoFiT
Can't buy it?, build it!
California
chain slipping off? alignment is key. possibly add an Adjuster Chain Tensioner. basically a spring loaded arm with a wheel on it. I mean a gear like on a 10 speed seems better to me. but i've always just seen a smooth wheel tensioner on go karts/mini bikes.
that way you can use a straight edge to make it perfect and not worry about tightening the motor down while adding tension and it shifting. just get it close to tight and straight. then tensioner to hold it on.
unless someone has better advice
Do like Denny suggests. I have two yerf-dogs, one with a predator and the other has a 196cc clone. They both have torque converter 30 series
(Transmission ) and 19" rear tires . Not only are they not sluggish, they accelerate hard. Go through the expense ( less than $100 ) and the trouble to install it and you will not be disappointed with the performance.
Brandon1320
Georgia
Follow up to this....
I bought this CVT from Amazon. It definitely gets up and goes a lot better now, but I lost my top end pretty much... I was going 36mph before using an app on my phone but now its a lot slower (I didn't get a chance to get an mph because my son hit a fence post and bent an A-arm and the axle but he's fine) but it's noticeably slower. Is that how it's going to be with the CVT? Is there something I need to change/adjust? It has the same gearing as before.
not sure what's going on with your setup. Are you getting into high gear to early and lugging the engine down or are you wound up pretty good and just topped out on rpm? You don't need a tachometer just judge by ear. Mine go 34 mph according to my grandsons phone. If you are lugging down there are two ways you can go at this to get your engine up into the upper RPM range. A smaller drive sprocket 8 or 9 tooth on the clutch Jack shaft or change to the yellow spring on the driven clutch. Each part is about 14to 15 $. The stiffer yellow spring will keep it in a lower ratio longer. If it's not bogging down but you are topped out on rpm then to get more revs out of the engine you need to remove the govoner. That's what I have in mine along with a stage one kit which is a larger jet in the carburetor, low restriction air filter, header pipe with performance muffler and a little stiffer valve springs. A stage one kit is sold by several of the kart supply shops and takes the guess work out of it so you get components that are going to work together correctly.
Brandon1320
Georgia
It didn't seem like it was bogging down at all. I didn't pay attention to the RPMs though. It just jumps up real quick and gets going but peaks pretty quick then gradually speeds up with enough distance. After the holidays I'll get the broken parts replaced and try to pay more attention to what it is doing. I'll probably start with the spring, I don't want to break into the motor.... I bought the warranty so I would like to keep that intact.
from your general description sounds like you are not lugging but on the govoner. If you don't want to mess with getting more rpm then taller gearing could get you more top speed. With a tag line of 1320 that says drag racer to me. If so you should have a good understanding of how gearing works.If the engine is producing enough torque then a 12 tooth sprocket could get you more top speed if it has the guts to reach maximum rpm, 3600 at the cost of some acceleration. 7 hp and limited rpm are only going to do so much.
As an aside, how are the brakes ? You said your son drove into a post. Was it because of bad brakes or is he so young and inexperienced he didn't know what to do ? I put my first grandsons in a kart at 5, but the first 3 or 4 times we took him out to a dry lake bed where there was nothing to hit, until he got the hang of it. He is now almost 18 and I am building predator engines that are
pushing 18 to 20 hp at 7500 + rpm and it's never enough. Both of my Yerf-Dog
karts came with seat belts and I hope yours did to. If not get them for your son. I am a pretty big guy and non of the 4 karts I own will the belts fit me but I don't let any of my grandkids drive with out wearing them.
Brandon1320
Georgia
The brakes work fine. It has rained here the past few days and he was riding a thin, leaf covered trail. Trees on one side and a chain link fence on the other. He came down a little hill into a slight left and clipped the pole with the front tire. I'm assuming he was just getting cocky because the more he went around the faster he was starting to go. He told me he tried turning and it didn't so I guess he just slid across the leaves. I'm going to have to replace the right a-arm and somehow the rear axle.
Once I get it going again I'll try to pay more attention to what the engine is doing and how it sounds.
If you have an aftermarket belt it may be slipping, a lot. Change the belt to a Genuine Comet belt. It will save trouble later.
Brandon1320
Georgia
I have the belt that came with the kit on there. I figured I would run it until it was no good. I know in your first post you recommended getting a better belt right from the start.
