600cc Motorcycle Engine - Clutch Wear
daveypoo
New York, USA
Hello, I looked through some already made forums, and I could not find any answers for my questions.
I want to preface this by saying I am not sure if this is the correct website to ask this type of question, but if there is already a forum with this topic, please refer me to it.
I am looking to make a utility vehicle out of a motorcycle engine. It will be made with a mid-sized bed and constantly used to tow trailers, pulling a good amount of weight behind it. I am unsure of the exact engine as of right now, but I know I want at least a 600cc engine. My plan is to make it have 2 sets of rear axles, both driven by the engine, so it will be a 6x4.
Long story short, I am wondering how the clutch will fair in the process. Obviously, if I just threw the engine into a utility vehicle without major gear reduction, it will drive way too fast and burn the clutch.
The question I am trying to answer is this:
If I used a jackshaft to majorly gear down the drive ratio, would the clutch still be prone to wear? In terms of mechanical advantages, will the clutch be able to stand up to abuse in terms of pulling heavy weight behind it? Regardless of the final drive ratio, does the clutch still see the same amount of stress?
Thanks for any and all responses.
If you plan to just take an engine out of some used motorcycle bought for the engine, you'll already have a manual clutch and a transmission built right onto it. If gear ratio for pulling a load is an issue, you can run a separate jackshaft for a lower ratio than available via just a single chain from the drive sprocket to the axle sprocket.
If you want the automatic clutch action of a common centrifugal without burning it up, well, hopefully somebody here will have a better idea how to do it than I do.
Yes, you an use a jackshaft to gear down. And yes it will save your clutch some depending how much you gear down. And yes you will still have an operable however many speed transmission the engine has. If you want it to pull a house down you could stick to the original ratio to the jack shaft, from the jack shaft a 10 tooth sprocket to a 60 tooth axle sprocket. For example. Then you better think about good brakes.
daveypoo
New York, USA
Tow trailers? About how much weight are we talking here? What kind of terrain will you be driving on?
Trailers full of cut down trees, jetskis, boats, etc. Not pulling anything ridiculously heavy.
It will be on road and grass, not perfectly flat, but not ridiculously bumpy either.
The plan is to gear it down enough where my top speed is about 50ish in my highest gear.
daveypoo
New York, USA
The whole point of the post is about the clutch of the motorcycle engine..
The plan is to gear it down so that in it's highest gear, it maxes out around 50ish MPH. So yes, that will involve using a jackshaft to majorly reduce the final drive gear ratio. (I guess its actually increasing the gear ratio, depending on how you look at it, but I think you get the point ahahah).
I definitely, obviously, do not want to use some kind of crappy centrifugal clutch, such as a torque convertor. The point of this project is to use a motorcycle engine, but hopefully without burning up it's clutch.
daveypoo
New York, USA
My latest project was a fully custom built go kart, with a 301cc predator engine, 40 series torque convertor, and a jackshaft that reduced its final drive ratio by a quarter. There was absolutely no way I could hold that thing back if it took off; I am able to tow a full sized trailer loaded with cut down trees no problem.
Thank you for answering my question, I was concerned that even if it was extremely geared down, it would still wear down the clutch. I hypothesized it would be fine, but posed the question on this forum to confirm.
65ShelbyClone
SoCal
It's not regardless of the final drive ratio. A numerically higher ratio will make life easier for whatever is upstream of it (like the engine and clutch) and harder for whatever is downstream.
