Tillotson Wildcat 223
Willie1
Newport, Mi
Anybody here have any experience with one of the 223 Wildcat engines? Seems to be something that EC Carbs is involved with. 70mm bore, 58 mm stroke in a reinforced block and side cover. Apparently they have a "hi velocity" Hemi head which shares some but not all generic Hemi parts. They have a 4K RPM limited coil and a lightened flywheel. I see a lot of mention about the T/son 225's but not the Wildcat 223's. Grey Goat from OMB was doing one, but he quit posting videos for a while. I plan on doing a basic stage 1 mod to mine for a trike I'm building, but I don't expect it to be done until spring. So has anyone here used one, and if so - any feedback? Thanks
ONE-EYE
Knoxville, Tennessee
I don't have a Wild Cat personally but it'll probably be the next one I buy. They seem to be pretty solid engines and they claim to have the most torque for their size. A lot of the parts/upgrades are interchangeable with the Tillotson as well so that's definitely a plus. Good price too. I'm sure you won't be disappointed.
Willie1
Newport, Mi
It looks like there are a few quirks to them that the parts don't interchange. The Wildcat has a 7 bolt side cover that is beefed up and takes a special gasket. The head is different and take 2 different length studs. I think the intake and/or the exhaust flange is different. Since I don't like the way the carb and air filter sticks out from the side of the engine I plan on making an intake to aim the carb straight back, along with a custom exhaust. Not really going for big power - I feel the "weak link" is the differential axle I have - it is a Peerless 100 with 3/4" axles. But I had 1 on the shelf and I have various mower wheels and tires for the rear, so it's cost effective. And being electric start there are no billet flywheels available anyways, so if I can see 9-10hp and 4500rpm I will be happy. When I get into the engine I will post updates.
Flyinhillbilly
The great cornholio
North West Arkansas
I bought one and built it. The standard billet side cover will fit, it just doesn’t use the 7th bolt, a non hemi head will bolt right on with different bolts, clone (hemi) cams fit, as well as clone billet rod, and flywheel.
Willie1
Newport, Mi
Good info - thanks.
While the non - Hemi Predator I had purchased probably would have been fine for what I'm doing, by the time I converted it to electric start and a few other mods, I still probably would have had the same money in less power and a weaker block.
Flyinhillbilly
The great cornholio
North West Arkansas
Good info - thanks.
A lot of people prefer the non hemi. The hemi will go right on it, but the truth is that I think the stock wild at head is better.
